esp_wifi_set_country returns ESP_ERR_WIFI_ARG
gatisp
Postby gatisp » Mon Oct 30, 2017 8:05 am
I wanted to limit the possible channels the station is scanning when trying to connect using the esp_wifi_set_country API:
    wifi_country_t country = {
	.cc = "EU",
	.schan = 3,
	.nchan = 1,
	.policy = WIFI_COUNTRY_POLICY_AUTO,
    int ret = esp_wifi_set_country(&country); // returns ESP_ERR_WIFI_ARG
But esp_wifi_set_country seems to return ESP_ERR_WIFI_ARG for anything that specifies schan other than 1. Also the nchan does not seem to be respected, as the ESP32 still connects to APs outside of the channel range [schan, schan + nchan).
Could somebody please give an update on how this API is supposed to work?
Hope it is not a problem to ask questions about APIs in master branch!
Thanks for all the good stuff thats coming into the ESP-IDF!
WiFive
Re: esp_wifi_set_country returns ESP_ERR_WIFI_ARG
Postby WiFive » Mon Oct 30, 2017 9:02 am
Did you try WIFI_COUNTRY_POLICY_MANUAL? It may not be possible to use something that is not a known standard.
gatisp
Postby gatisp » Mon Oct 30, 2017 10:15 am
Same results with WIFI_COUNTRY_POLICY_MANUAL...
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot] and 1 guest
