Can't flash from ubuntu terminal - serial port permissions denied
rwel59
Postby rwel59 » Sun Nov 05, 2017 7:18 pm
I have just switched over from windows to linux for esp32 development. I can communicate with esp32 (verified with putty and make menuconfig) but when I try to flash a program I get an error message: could not open port xxx, permission denied.
I can get around that with sudo chmod 777 xxport but that only lasts as long as my session. I assume that I need to give python permission to the serial port but I cannot figure out how.
I will be moving on to eclipse environment and out of console - guessing that this issue would follow.
Re: Can't flash from ubuntu terminal - serial port permissions denied
Postby Sprite » Mon Nov 06, 2017 5:52 am
Try 'sudo adduser [your username] dialout', then logging out and logging in again.
loboris
Postby loboris » Mon Nov 06, 2017 9:08 am
You can also add the udev rule for USBtoUART device used on ESP32 board.
Simple, add new rule file to the /etc/udev/rules.d directory, for example 98-esp32.rules with the content like this:
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6015", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6010", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="067b", ATTRS{idProduct}=="2303", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
idVendor&idProduct can be obtained with lsusb.
After changing the rules, you need to run:
sudo udevadm control --reload-rules
rwel59
Postby rwel59 » Mon Nov 06, 2017 1:35 pm
Solution (for me)
I failed to mention that I am working with Virtual Box on Windows 10 machine. These are the steps I used...
- close ubuntu session
- in Virtual Box, select settings->usb and add Silcon Labs uart to device filers. Save
- Open Ubuntu session. Tried to find the name of the esp32 device port but didn't have any luck. Lots of /dev/tty devices but no named usb. So I made the assumption that mine was /dev/ttyUSB0 as defined in default menuconfig
- Added myself to dialout group. Logged out and shutdown ubuntu session - most ideas I found googling said to log out and log back in but this did not work for me.
- Once I opened up a new session, I was able to flash
Gfast2
Postby Gfast2 » Mon Nov 06, 2017 2:08 pm
Surely I got the same issue, you can try my solution either:
sudo chown <yourname> /dev/ttyUSB0
I'm running my ubuntu in Virtualbox which is hosted by windows10, too. As default, when a usb device is set to connect to VM, it's owner is root but not you. So you have to "Fix" it. :lol:
rwel59
Postby rwel59 » Thu Nov 16, 2017 1:56 am
Just to clarify what worked for me. I added my to dialout group but it did not take effect logging out and back in to ubuntu. I had to shut ubuntu down. After starting a new ubuntu session, I was now added to the dialout group with access to the usb
marcusob
Postby marcusob » Sat Oct 15, 2022 7:08 am
To get over the permission denied - I am running Windows 10 Host, with VMWare Ubuntu 20.04.1 guest
File "/home/marcus/.espressif/python_env/idf3.3_py2.7_env/lib/python2.7/site-packages/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 13] could not open port /dev/ttyUSB0: [Errno 13] Permission denied: '/dev/ttyUSB0'
make: *** [/home/marcus/esp-idf/components/esptool_py/Makefile.projbuild:71: flash] Error 1
I had to do both of these
sudo adduser <yourname> dialout
I did have to log out and back in after the adduser for it to take effect, but didnt have to log out and back in for the chown to take affect.
Users browsing this forum: Semrush [Bot] and 1 guest
