Undefined reference to `xPortGetFreeHeapSizeCaps(unsigned int)
abcdcadb
Postby abcdcadb » Wed Nov 15, 2017 9:38 am
I tried using xPortGetFreeHeapSizeCap to check the free heap of esp.
I create a "reference.c" in the same folder with main.c, inside reference.c I define reference function:
#include"reference.h"
extern "C" {
#include "esp_heap_alloc_caps.h"
extern void SmbDaemon()
printf( "\n entered checking function");.
printf("\n free 32bit heap is %d",xPortGetFreeHeapSizeCaps(MALLOC_CAP_32BIT));
in "reference.h" i declare:
. and in main.c i call SmbDaemon()
i got this
" Undefined reference to `xPortGetFreeHeapSizeCaps(unsigned int) when compiling"
if i remove "printf("\n free 32bit heap is %d",xPortGetFreeHeapSizeCaps(MALLOC_CAP_32BIT));" i can compile and enter SmbDaemon()
However, If i directly call printf("\n free 32bit heap is %d",xPortGetFreeHeapSizeCaps(MALLOC_CAP_32BIT))in main.c, code can be compiled and work well.
what should i modify?
kolban
Re: Undefined reference to `xPortGetFreeHeapSizeCaps(unsigned int)
Postby kolban » Wed Nov 15, 2017 5:48 pm
I'm not fully following your puzzle ... but I see that xPortGetFreeHeapSizeCaps() has been deprecated in favor of heap_caps_get_free_heap_size(). May I suggest that you read the docs on that API and replace your reference to xPortGetFreeHeapSizeCaps() in your source with the new API.
abcdcadb
Postby abcdcadb » Thu Nov 16, 2017 12:13 am
Iam working on idf 2.0 and there is another function is esp_get_free_heap_size.
however, it gives different result from xPortGetFreeHeapSizeCap and I dont know which is more trustworthy
may i will try IDF 3.0
Angus
Postby Angus » Thu Nov 16, 2017 4:03 am
If your source is really .c and not .cpp then try removing the extern "C" block from around the #include.
Do you get any other warnings or errors from the compiler before that one?
abcdcadb
Postby abcdcadb » Thu Nov 16, 2017 4:50 am
previously, i didnt have extern C, i added it after reviewing some posts, the result is identical.
it almost finishes compiling (it can recognize esp_heap_alloc_caps.h) and being export reference.o file, the error occurs and stop
Angus
Postby Angus » Thu Nov 16, 2017 5:35 am
Can you please post the full output of "make V=1"?
Please copy it onto a site like https://pastebin.com or https://gist.github.com and then post a link to the forum.
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], Qwantbot and 2 guests
