AT response (+IPD) adding linebreaks?
aferran
Postby aferran » Fri Dec 22, 2017 9:41 am
I'm using an esp32 on custom board based on a TI am335x uC, and I'm using AT commands to control it.
Everything seems to work fine, but when I'm sending a http request using AT+CIPSEND, and read the response after +IPD, it seems that there is an extra line break after each lines, which prevent curl to parse the answer properly (see example below.). Is there a way to prevent that?
I'm using:
AT version:1.0.0.0(870285c - Nov 14 2017 07:26:38)
SDK version:v2.1-65-g8bca703
compile time:Nov 17 2017 07:53:25
Bin version(Wroom32):1.0.0
Thanks,
Antoine
HTTP response example:
HTTP/1.1 200 OK
X-Powered-By: Express
Access-Control-Allow-Origin: *
Content-Type: application/json; charset=utf-8
Content-Length: 16
ETag: W/"10-c2PoX+nt7m8FOksxlYjAhg"
X-Response-Time: 0.544ms
Vary: Accept-Encoding
Date: Thu, 21 Dec 2017 17:15:24 GMT
Connection: keep-alive
{"success":true}
What I'm expecting:
HTTP/1.1 200 OK
Content-Length: 16
{"success":true}
Users browsing this forum: Bing [Bot] and 7 guests
