Getting started error
umagen9
Postby umagen9 » Fri Nov 04, 2016 4:14 pm
Hi! I just plugged in my ESP_WROOM_32 board and followed the 'ESP-IDF getting started guide'. I got this error - recipe for target 'bootloader-flash' failed.
What am I doing wrong? I would appreciate any help to get me started using this module!
kolban
Re: Getting started error
Postby kolban » Fri Nov 04, 2016 10:25 pm
What is the exact command you are running? It looks like a parameter error to esptool.py at first blush.
Angus
Postby Angus » Tue Nov 08, 2016 1:00 am
Hi umagen9,
I can confirm this is a bug in the esp-idf build system. I have a fix here, it should make it online soon.
In the meantime, "make flash" will work (flashes bootloader, partition table and app) and the command printed by "make bootloader" will also work.
Thanks for reporting this.
Angus
Users browsing this forum: Semrush [Bot] and 2 guests
