some questions when use IRAM_ATTR
edisonPan
Postby edisonPan » Wed Jan 10, 2018 1:17 am
dear:
in my esp32 app,there is a Timer group0 ISR handler,as follow:
float dataFloat;
int dataInt;
void IRAM_ATTR imer_group0_isr(void *para)
dtaInt = 123;
dataFloat = (float)dataInt;
// will be error when i use "make monitor" to run it,but it is ok when compile when i use "make flash"
void Test_int_to_float()
dtaInt = 123;
// it is ok
in the IRAM_ATTR function,the software will reboot because of "dataFloat = (float)dataInt",,,but when i put this in a function has no "IRAM_ATTR " ,it is ok.
please help me ,thanks!
Re: some questions when use IRAM_ATTR
Postby Sprite » Wed Jan 10, 2018 2:16 am
Sorry, you can't use floating point calculations in an ISR at the moment because the ISR handler does not save/restore the floating point coprocessor state.
Users browsing this forum: ChatGPT-User, PetalBot and 2 guests
