Ping from ESP32
Ping from ESP32
What APIs can be used to ping to an address from ESP32? I can see that there is ping_send in lwip/apps/ping but this function header is not available. The header file only provides ping_init().
Re: Ping from ESP32
This is a old question but just in case it helps the next guy....
It took me a while to figure out how to use the ping api but just create a pingResults function and make some calls to esp_ping_set_target to config things and call ping_init();
also in eps_ping.c I got rid of the "x 1000" multipliers and pass ping_timeout and ping_delay in mS
esp_err_t pingResults(ping_target_id_t msgType, esp_ping_found * pf){
app_main() {
esp_ping_set_target(PING_TARGET_IP_ADDRESS_COUNT, &ping_count, sizeof(uint32_t));
esp_ping_set_target(PING_TARGET_RCV_TIMEO, &ping_timeout, sizeof(uint32_t));
esp_ping_set_target(PING_TARGET_DELAY_TIME, &ping_delay, sizeof(uint32_t));
esp_ping_set_target(PING_TARGET_IP_ADDRESS, &gw.addr, sizeof(uint32_t));
esp_ping_set_target(PING_TARGET_RES_FN, &pingResults, sizeof(pingResults));
ping_init();
Andy_Odessa
Re: Ping from ESP32
Hi!
Thanks for this code example! Is it possible to give some explanation or example of function pingResults? It will be wery helpful for understanding.
Re: Ping from ESP32
Hello,This is a old question but just in case it helps the next guy....
also in eps_ping.c I got rid of the "x 1000" multipliers and pass ping_timeout and ping_delay in mSCode: Select all
esp_err_t pingResults(ping_target_id_t msgType, esp_ping_found * pf){ ... } app_main() { .... esp_ping_set_target(PING_TARGET_IP_ADDRESS_COUNT, &ping_count, sizeof(uint32_t)); esp_ping_set_target(PING_TARGET_RCV_TIMEO, &ping_timeout, sizeof(uint32_t)); esp_ping_set_target(PING_TARGET_DELAY_TIME, &ping_delay, sizeof(uint32_t)); esp_ping_set_target(PING_TARGET_IP_ADDRESS, &gw.addr, sizeof(uint32_t)); esp_ping_set_target(PING_TARGET_RES_FN, &pingResults, sizeof(pingResults)); ping_init(); ... }
I have also try to understand ping with ESP32, can you provide full code example perryc ?
Thank you.
Re: Ping from ESP32
All your ping info is in the pf struct
printf("AvgTime:%.1fmS Sent:%d Rec:%d Err:%d min(mS):%d max(mS):%d ", (float)pf->total_time/pf->recv_count,
pf->send_count, pf->recv_count, pf->err_count, pf->min_time, pf->max_time );
return ESP_OK;
}Re: Ping from ESP32
Here's a simple ping app that's based on esp-idf wifi ap example code
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_spi_flash.h"
#include "freertos/event_groups.h"
#include "esp_wifi.h"
#include "esp_log.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "lwip/inet.h"
#include "lwip/ip4_addr.h"
#include "lwip/dns.h"
#include "ping.h"
#include "esp_ping.h"
/*Set the SSID and Password via "make menuconfig"*/
#define DEFAULT_SSID CONFIG_WIFI_SSID
#define DEFAULT_PWD CONFIG_WIFI_PASSWORD
#define TRUE 1
#define FALSE 0
#if CONFIG_WIFI_ALL_CHANNEL_SCAN
#define DEFAULT_SCAN_METHOD WIFI_ALL_CHANNEL_SCAN
#elif CONFIG_WIFI_FAST_SCAN
#define DEFAULT_SCAN_METHOD WIFI_FAST_SCAN
#else
#endif /*CONFIG_SCAN_METHOD*/
#if CONFIG_WIFI_CONNECT_AP_BY_SIGNAL
#define DEFAULT_SORT_METHOD WIFI_CONNECT_AP_BY_SIGNAL
#elif CONFIG_WIFI_CONNECT_AP_BY_SECURITY
#define DEFAULT_SORT_METHOD WIFI_CONNECT_AP_BY_SECURITY
#else
#endif /*CONFIG_SORT_METHOD*/
#if CONFIG_FAST_SCAN_THRESHOLD
#define DEFAULT_RSSI CONFIG_FAST_SCAN_MINIMUM_SIGNAL
#if CONFIG_EXAMPLE_OPEN
#define DEFAULT_AUTHMODE WIFI_AUTH_OPEN
#elif CONFIG_EXAMPLE_WEP
#define DEFAULT_AUTHMODE WIFI_AUTH_WEP
#elif CONFIG_EXAMPLE_WPA
#define DEFAULT_AUTHMODE WIFI_AUTH_WPA_PSK
#elif CONFIG_EXAMPLE_WPA2
#define DEFAULT_AUTHMODE WIFI_AUTH_WPA2_PSK
#else
#endif
#else
#define DEFAULT_RSSI -127
#define DEFAULT_AUTHMODE WIFI_AUTH_OPEN //WIFI_AUTH_WPA2_PSK
#endif /*CONFIG_FAST_SCAN_THRESHOLD*/
static const char *TAG = "scan";
int gotConn = FALSE;
int first = TRUE;
ip_addr_t ip_Addr;
ip4_addr_t ip;
ip4_addr_t gw;
ip4_addr_t msk;
uint32_t ping_count = 25; //how many pings per report
uint32_t ping_timeout = 1000; //mS till we consider it timed out
uint32_t ping_delay = 500; //mS between pings
uint32_t waiting_results = 0;
static esp_err_t event_handler(void *ctx, system_event_t *event)
switch (event->event_id) {
case SYSTEM_EVENT_STA_START:
ESP_LOGI(TAG, "SYSTEM_EVENT_STA_START");
ESP_ERROR_CHECK(esp_wifi_connect());
break;
case SYSTEM_EVENT_STA_GOT_IP:
ESP_LOGI(TAG, "SYSTEM_EVENT_STA_GOT_IP");
ip = event->event_info.got_ip.ip_info.ip;
gw = event->event_info.got_ip.ip_info.gw;
msk = event->event_info.got_ip.ip_info.netmask;
ESP_LOGI(TAG, "Got IP: %s\n",
ip4addr_ntoa(&event->event_info.got_ip.ip_info.ip));
gotConn=TRUE;
break;
case SYSTEM_EVENT_STA_DISCONNECTED:
ESP_LOGI(TAG, "SYSTEM_EVENT_STA_DISCONNECTED");
gotConn=FALSE;
ping_deinit();
break;
default:
break;
return ESP_OK;
/* Initialize Wi-Fi as sta and set scan method */
static void wifi_scan(void)
tcpip_adapter_init();
ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
wifi_config_t wifi_config = {
.sta = {
.ssid = DEFAULT_SSID,
.password = DEFAULT_PWD,
.scan_method = DEFAULT_SCAN_METHOD,
.sort_method = DEFAULT_SORT_METHOD,
.threshold.rssi = DEFAULT_RSSI,
.threshold.authmode = DEFAULT_AUTHMODE,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
int getStrength(int points){
wifi_ap_record_t wifidata;
long rssi = 0;
long averageRSSI=0;
for (int i=0;i < points;i++){
if (esp_wifi_sta_get_ap_info(&wifidata)==0){
rssi += wifidata.rssi;
vTaskDelay(25 / portTICK_PERIOD_MS);
averageRSSI=rssi/points;
return averageRSSI;
printf("AvgTime:%.1fmS Sent:%d Rec:%d Err:%d min(mS):%d max(mS):%d ", (float)pf->total_time/pf->recv_count, pf->send_count, pf->recv_count, pf->err_count, pf->min_time, pf->max_time );
printf("Resp(mS):%d Timeouts:%d Total Time:%d\n",pf->resp_time, pf->timeout_count, pf->total_time);
return ESP_OK;
void app_main()
printf("esp32 Latency and Packdrop test!\n");
/* Print chip information */
esp_chip_info_t chip_info;
esp_chip_info(&chip_info);
printf("This is ESP32 chip with %d CPU cores, WiFi%s%s, ",
chip_info.cores,
(chip_info.features & CHIP_FEATURE_BT) ? "/BT" : "",
(chip_info.features & CHIP_FEATURE_BLE) ? "/BLE" : "");
printf("silicon revision %d, ", chip_info.revision);
printf("%dMB %s flash\n", spi_flash_get_chip_size() / (1024 * 1024),
(chip_info.features & CHIP_FEATURE_EMB_FLASH) ? "embedded" : "external");
// Initialize NVS
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK( ret );
wifi_scan();
vTaskDelay(5000 / portTICK_PERIOD_MS);
while(TRUE) {
if ((gotConn)&&(!waiting_results)) {
printf("\nPinging Gateway IP %s WiFi rssi %d\n",inet_ntoa(gw),getStrength(10));
if (first){
first = FALSE;
printf("%s, %d, ",inet_ntoa(gw),getStrength(10));
ping_init();
waiting_results = 1;
Re: Ping from ESP32
Hi @perryc.
I'm using this code here and was running into cases where the pinging was taking forever to timeout or complete.
The delay and timeout values are in seconds, see esp_ping_set_target():
The ping thread in ping.c uses sys_msleep() which is documented as:
case PING_TARGET_RCV_TIMEO:
ESP_PING_CHECK_OPTLEN(opt_len, uint32_t);
ping_option_info->ping_rcv_timeout = (*(uint32_t *)opt_val) * 1000;
break;
case PING_TARGET_DELAY_TIME:
ping_option_info->ping_delay = (*(uint32_t *)opt_val) * 1000;
/* Time functions. */
#ifndef sys_msleep
void sys_msleep(u32_t ms); /* only has a (close to) 1 ms resolution. */
#endif
Re: Ping from ESP32
There is a feb 25/18 bug fix for the esp-idf that gets rid of the of the "* 1000" in esp_ping.c so grab the latest esp-idf and you can pass normal milliseconds time params.
pratik.yadav.455
Re: Ping from ESP32
Hello
I am using ping functionality with following configuration
my call call function is as following
ISSUE is
I am using my ethernet.
After 2 ping if i remove Ethernet cable i am not able to get callback(As my ping count is 5).
Also when i connect Ethernet cable again. fail ping init with -5 error which shows ping is ongoing.
If ping is fails then why i am not getting call back with increased error count ?
am i missing anything or miss understood?
if anyone have idea about it please help me.
PING_TARGET_IP_ADDRESS_COUNT 5
PING_TARGET_RCV_TIMEO 10000
PING_TARGET_DELAY_TIME 500
PING_TARGET_IP_ADDRESS "www.google.com"
PING_TARGET_RES_FN pingResults
ESP_LOGI(TAG,"AvgTime:%.1fmS Sent:%d Rec:%d Err:%d min(mS):%d max(mS):%d", (float) pf->total_time / pf->recv_count, pf->send_count, pf->recv_count, pf->err_count, pf->min_time, pf->max_time);
ESP_LOGI(TAG,"Resp(mS):%d Timeouts:%d Total Time:%d Bytes :%d Total Bytes: %d\n", pf->resp_time, pf->timeout_count, pf->total_time, pf->bytes, pf->total_bytes);
if(pf->err_count == 0){
++ping_count_local;
if(ping_count_local >= ping_count){
ping_sucess_flag = ping_external_success;
else{
ping_sucess_flag = ping_external_failed ;
return ESP_OK;
Re: Ping from ESP32
I have been trying for a while to make this ping work without success.
From the code above which I have simplified to the max, I still ahve issues:
Appologies, I have not been doing this for a long time.
"ping_init not declared in this scope"
It seems it can't find this although ping.c is included....
This is the error message.
And this is my code:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "LOLIN D32, Minimal SPIFFS (Large APPS with OTA), 80MHz, 512000, None"
C:\Users\etawy\OneDrive\Development\Arduino\TestSketches\ping_test\ping_test.ino: In function 'void loop()':
ping_test:95:13: error: 'ping_init' was not declared in this scope
ping_init();
Multiple libraries were found for "WiFi.h"
Used: C:\Users\etawy\OneDrive\Documents Perso\ArduinoData\packages\esp32\hardware\esp32\1.0.2\libraries\WiFi
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\WiFi
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
#include <stdio.h>
#include "lwip/ip_addr.h"
// to make this work for v1.01 just change in file Ping.cpp in your library path:
// inet_addr_from_ipaddr to inet_addr_from_ip4addr
// inet_addr_to_ipaddr to inet_addr_to_ip4addr
#include "ping.h"
#include <WiFi.h>
//ip_addr_t ip_Addr;
ip4_addr_t gw;
#define PING_TARGET_IP_ADDRESS_COUNT 5
#define PING_TARGET_RCV_TIMEO 10000
#define PING_TARGET_DELAY_TIME 500
#define PING_TARGET_IP_ADDRESS "www.google.com"
#define PING_TARGET_RES_FN pingResults
// the setup function runs once when you press reset or power the board
const char ssid[] = "SFR-XXXX"; // your network SSID (name)
const char password[] = "XXXXXXXX"; // your network password
void setup() {
Serial.begin(115200);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
esp_err_t pingResults(ping_target_id_t msgType, esp_ping_found * pf) {
printf("AvgTime:%.1fmS Sent:%d Rec:%d Err:%d min(mS):%d max(mS):%d ", (float)pf->total_time / pf->recv_count, pf->send_count, pf->recv_count, pf->err_count, pf->min_time, pf->max_time );
printf("Resp(mS):%d Timeouts:%d Total Time:%d\n", pf->resp_time, pf->timeout_count, pf->total_time);
return ESP_OK;
int getStrength(int points) {
long rssi = 0;
long averageRSSI = 0;
for (int i = 0; i < points; i++) {
if (esp_wifi_sta_get_ap_info(&wifidata) == 0) {
averageRSSI = rssi / points;
return averageRSSI;
void loop() {
gw.addr = ipaddr_addr("8.8.8.8");
//esp_ping_set_target(PING_TARGET_RES_FN, &pingResults, sizeof(pingResults));
printf("\nPinging Gateway IP %s WiFi rssi %d\n", inet_ntoa(gw), getStrength(10));
printf("%s, %d, ", inet_ntoa(gw), getStrength(10));
ping_init();
}Who is online
Users browsing this forum: Applebot, Bytespider, ChatGPT-User, Qwantbot and 4 guests
