Pin mapping
mistergreen
Pin mapping
Postby mistergreen » Sat Feb 03, 2018 8:26 pm
On the Arduino you can pin map like so
pinMode(A0, OUTPUT);
digitalWrite(A0, HIGH);
Since there are so many analog input pins, it would be good to convert it to a digital pin. I've tried this but it doesn't work for the ESP32.
Is this still in the works or it isn't possible?
WiFive
Re: Pin mapping
Postby WiFive » Sun Feb 04, 2018 4:37 am
It should work except 34-39.
mistergreen
Re: Pin mapping
Postby mistergreen » Sun Feb 04, 2018 3:12 pm
Ah thanks. That worked. Just curious why not pin 34-39?
Re: Pin mapping
Postby rudi ;-) » Sun Feb 04, 2018 9:11 pm
if you use the right board, it os possible, some boards 37,38 is not breakout for reason
do you want use it as OUTPUT digital or INPUT digital?
some pins need extra knowledge example 37,38
but this is done in the arduino ide
example was:
#include <driver/adc.h>
void setup() {
 Serial.begin(115200);
 adc1_config_width(ADC_WIDTH_12Bit);
 adc1_config_channel_atten(ADC1_CHANNEL_1, ADC_ATTEN_6db);//channel_1 for GPIO37 and 2 for 38.
void loop() {
 int value = adc1_get_voltage(ADC1_CHANNEL_1);
 Serial.println(value);
 delay(1000);
note, that 37,38 have exta HDK Low-Noise Amplifier in this version under 28.4 ( can be changed in next version )
