Wake Up - ADC - Hall Sensor
sslama
Postby sslama » Tue Feb 06, 2018 11:09 am
for a prototyping project I'm looking for a developer that can help us.
It is an university project, improving the hygiene in the health care sector.
I need the ESP32 to wake up from the deep sleep mode if the hall sensor detects a measurement over a certain threshold. My understanding ist, that the ULP can read the current value of the hall sensor over the ADC.
As I don't have much experience in Assembler and the examples using the ULP are quite vague any help is very much appreciated.
Best regards,
Simon
brandobur
Re: Wake Up - ADC - Hall Sensor
Postby brandobur » Wed Jul 11, 2018 12:45 pm
maybe it will help, I have written it today (works also in Arduino IDE):
#include "esp32/ulp.h"
#include "soc/rtc_cntl_reg.h"
#include "driver/rtc_io.h"
#include "driver/adc.h"
void ulp_adc_wake_up(unsigned int low_adc_treshold, unsigned int high_adc_treshold)
   adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);
   adc1_config_width(ADC_WIDTH_BIT_10);
   adc1_ulp_enable();
   rtc_gpio_init(GPIO_NUM_36);
   const ulp_insn_t program[] = {
      I_DELAY(32000),              // Wait until ESP32 goes to deep sleep
      M_LABEL(1),                  // LABEL 1
        I_MOVI(R0, 0),             // Set reg. R0 to initial 0
        I_MOVI(R2, 0),             // Set reg. R2 to initial 0
      M_LABEL(2),                  // LABEL 2
        I_ADDI(R0, R0, 1),         // Increment cycle counter (reg. R0)
        I_ADC(R1, 0, 0),           // Read ADC value to reg. R1
        I_ADDR(R2, R2, R1),        // Add ADC value from reg R1 to reg. R2
      M_BL(2, 4),                  // If cycle counter is less than 4, go to LABEL 2
      I_RSHI(R0, R2, 2),           // Divide accumulated ADC value in reg. R2 by 4 and save it to reg. R0
      M_BGE(3, high_adc_treshold), // If average ADC value from reg. R0 is higher or equal than high_adc_treshold, go to LABEL 3
      M_BL(3, low_adc_treshold),   // If average ADC value from reg. R0 is lower than low_adc_treshold, go to LABEL 3
      M_BX(1),                     // Go to LABEL 1
      M_LABEL(3),                  // LABEL 3
      I_WAKE(),                    // Wake up ESP32
      I_END(),                     // Stop ULP program timer
      I_HALT()                     // Halt the coprocessor
   size_t size = sizeof(program)/sizeof(ulp_insn_t);
   ulp_process_macros_and_load(0, program, &size);
   ulp_run(0);
   esp_sleep_enable_ulp_wakeup();
   esp_deep_sleep_start();
Best regards,
Marek
gabriel-milan
Postby gabriel-milan » Tue May 28, 2019 10:20 pm
Hey!
I was having a similar issue and realized there's few material on the internet for that.
I've written a very simple code for waking up ESP32 according to a threshold on hall sensor readings, hope it helps!
Link for the code: https://github.com/gabriel-milan/esp32_ulp_hall_wakeup
janbenes
Postby janbenes » Fri Feb 26, 2021 12:33 pm
Hello Marek,
your code does not compile for me on Arduino, any advice what could be wrong? Here is error message:
/tmp/arduino_build_150223/core/core.a(main.cpp.o):(.literal._Z8loopTaskPv+0x8): undefined reference to `setup()'
/tmp/arduino_build_150223/core/core.a(main.cpp.o):(.literal._Z8loopTaskPv+0xc): undefined reference to `loop()'
/tmp/arduino_build_150223/core/core.a(main.cpp.o): In function `loopTask(void*)':
/home/janbenes/.arduino15/packages/esp32/hardware/esp32/1.0.5/cores/esp32/main.cpp:32: undefined reference to `setup()'
/home/janbenes/.arduino15/packages/esp32/hardware/esp32/1.0.5/cores/esp32/main.cpp:35: undefined reference to `loop()'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board ESP32 Dev Module.
Best regards, Jan
   adc1_ulp_enable();
   ulp_run(0);
Best regards,
Marek
pipi61
Postby pipi61 » Wed Mar 23, 2022 10:43 pm
Hi!
Dear Brandobur!
I tried this example in Arduino.
in setup () I call ulp_adc_wake_up (unsigned int low_adc_treshold, unsigned int high_adc_treshold) with different parameters, but it always wakes up the processor without a magnet.
The arduino hallread() return integer value, i look 80-100 without magnet, with magnet one pole 560, other pole -440 negative value
You use unsigned integer, I tried (1, 4200000000) and vice versa, and many other values.
What can be the usable range?
xien551
Postby xien551 » Wed Mar 23, 2022 11:43 pm
Excellent project, I think it would work for all the ultra-low power application. I will try the code in my project in the future.
atmoz_
Postby atmoz_ » Tue May 03, 2022 3:04 pm
   adc1_ulp_enable();
   ulp_run(0);
Best regards,
Marek
Hi Marek,
Thanks for your code.
Can you please tell me how I must run this?
What has to be in the setup() function for example, and what has to be in de main loop?
Do I have to call ulp_adc_wake_up(0, 3500); only once or (very fast) in a loop?
I want to read ADC values from an IR-sensor, so I want to check the ADC-value as much as possible in order to detect things properly.
Thanks for thinking with me :-)
Best regards,
Atmoz
atmoz_
Postby atmoz_ » Thu May 05, 2022 6:04 am
Does anyone here on this forum how I should run this code?
The only thing I want is to read ADC in ULP and if a specific value is reached --> wake up the main processor.
Any help is appreciated 8-)
Thanks in advance!
Atmoz
Users browsing this forum: Bing [Bot], Bytespider, Semrush [Bot] and 9 guests
