I want to find out the revision of my ESP32 Chip. I know that there is a prepared Arduino function which you can run. But I dont use the Arduino library. As far as I know the Revision number is stored in a register somewhere but it can be damaged if the coder does something wrong. So I wanted to ask if there is a fail safe code for non-Arduino-users.
Find out the Revision of the ESP32 Chip
Re: Find out the Revision of the ESP32 Chip
Damn, I was searching for hours just to find out its in the hello world example
. Thank you very much.
Users browsing this forum: Semrush [Bot] and 1 guest
