Anyone know if is there an 8266 ESP.getVcc() equivalent implemented on the ESP32 platform yet?
ESP.getVcc() equivalent?
Re: ESP.getVcc() equivalent?
I use adc1_get_voltage() and connect Vcc to analog pin. But the function is not viable yet. This is the best i can do with 12bit resolution and 11db attenuation
- ADC.jpg (37.93 KiB) Viewed 20258 times
tele_player
Vdd33 is an input to adc2 which will be available hopefully soon with a coexist driver for wifi
I have success with rom_phy_get_vdd33() , though it only seems to work when WiFi or BT is on.
If WiFi is on the reading is occasionally wildly out. With just BT on it is pretty stable.
Fortunately it doesn't take long at all to enable + disable BT in my setup() function before I enable WiFi.
My board has a voltage divider on an analogue input, and it too gives the occasional wildly out reading (in the opposite direction) with WiFi enabled, so it might be a just be a power issue in my specific setup.
