ESP32 hangs when using core 1
Foxtrot813
Postby Foxtrot813 » Sun Apr 08, 2018 6:47 am
Hello all,
I'm having a problem executing blink on Core 1. My ESP is the WeMos Lolin32 Lite. Tried to modify the priority, the task handler, add vTaskStartScheduler() in the end of code, all without success. Here's the code:
#include <stdio.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#define BLINK_GPIO 22
void blink_task(void *param)
    gpio_pad_select_gpio(BLINK_GPIO);
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
    while(1)
        gpio_set_level(BLINK_GPIO, 0);
        vTaskDelay(500 / portTICK_PERIOD_MS);
        gpio_set_level(BLINK_GPIO, 1);
void app_main()
	xTaskCreatePinnedToCore(blink_task, "Blink", 1000, NULL, 20, NULL, 0);
I'm using Eclipse Oxygen to program the ESP32. When I change it to core 1, it does not blink. There's something that I'm missing? :?
WiFive
Re: ESP32 hangs when using core 1
Postby WiFive » Sun Apr 08, 2018 8:49 am
&blink_task
Foxtrot813
Postby Foxtrot813 » Sun Apr 08, 2018 5:22 pm
Putting &blink_task in xTaskCreatePinnedToCore didn't solve the problem. The ESP32 still hangs, without blinking. Tried to increase stack size this time, also without results. If I change to core 0, it works, so apparently the problem is with core 1...but why?
Postby Sprite » Mon Apr 09, 2018 3:01 am
Perhaps in 'make menuconfig', you have set freertos to unicore mode? (Component config -> FreeRTOS -> Run FreeRTOS only on first core)?
WiFive
Postby WiFive » Mon Apr 09, 2018 5:21 am
Shouldn't xtaskcreatepinnedtocore do something other than fail silently like pick a valid core or print an error?
Foxtrot813
Postby Foxtrot813 » Mon Apr 09, 2018 10:24 am
Gosh, that was the problem. ESP32 is running fine on two cores now that I've changed that. Thank you!
It printed this for me:
C:/msys32/home/f813/esp/esp-idf/components/freertos/tasks.c:1072 (prvAddNewTaskToReadyList)- assert failed!
abort() was called at PC 0x40083d4a on core 0
But I had no clue what that meant...
Postby Sprite » Mon Apr 09, 2018 11:13 am
Yes, it should respond better to that and from memory, esp-idf also used to check this. We'll put a check for this back in.
Users browsing this forum: Bing [Bot], PetalBot and 1 guest
