Sim800L GSM module
migbur
Sim800L GSM module
Postby migbur » Thu Apr 12, 2018 10:18 am
Hi
Im using a GSM module, using :
#include <HardwareSerial.h>
HardwareSerial SIM800L(1);
setup:
Serial.begin(19200);
SIM800L.begin(9600, SERIAL_8N1, 16, 17);
While I used esp32 connectet to my PC works fine, if I disconnect the pc USB cable it loose GSM module connectivity.
Please help.
juan3211
Re: Sim800L GSM module
Postby juan3211 » Tue Apr 17, 2018 2:43 pm
check stability of your power supply for SIM800L, it need also up to 2A.
Probably is not a issue with ESP32, it is a issue with power supply.
migbur
Postby migbur » Fri May 25, 2018 10:21 am
Hi thanks, yes was not ESP problem, was low power input to the GSM module.
Problem solved
Users browsing this forum: ChatGPT-User, Qwantbot and 1 guest
