ESP32 LyraT Battery circuitry not working
glennhuber
Has anyone been successful powering and/or charging a battery connected to the ESP32 LyraT board? I have not!
Re: ESP32 LyraT Battery circuitry not working
I have tried and it worked well,wihch I used is a 2000 mAh,3.7V battery,What battery did you use ?
Maybe the problem is due not matching polarity of the battery connector as discussed in https://github.com/espressif/esp-adf/issues/9 ?Has anyone been successful powering and/or charging a battery connected to the ESP32 LyraT board? I have not!
“ Maybe the problem is due not matching polarity of the battery connector as discussed in https://github.com/espressif/esp-adf/issues/9 ?”
—— Sure,you need to make sure the battery JST connector pins match the pin layout on the board appropriately.
Users browsing this forum: Bing [Bot] and 1 guest
