Using C++ Boost library on ESP32 - RTTI Error
ogensyts
Postby ogensyts » Fri Mar 30, 2018 3:33 am
i am trying to use Boost library on my ESP32 and get this error on Boost files when issuing 'make' :
 .... error: cannot use typeid with -fno-rtti
With this command on the terminal :
user@ubuntu:~$  xtensa-esp32-elf-gcc-5.2.0 -v
I can see configured with
.... --enable-cxx-flags='-fno-rtti ....
Can i remove this flag when issuing 'make' on my code to remove this error with Boost? If so how can i do it?
Or is it bad to do so ?
I am using Boost 1.53
Regards,
ogensyts
PaulVdBergh
Re: Using C++ Boost library on ESP32 - RTTI Error
Postby PaulVdBergh » Fri Mar 30, 2018 11:08 am
I have no experience with the boost libraries, but had the same isue with a dynamic_cast<>(). I solved it by adding the following line to the component.mk file:
CXXFLAGS += -frtti
Hope this helps.
Paul.
snahmad75
Postby snahmad75 » Sat Apr 28, 2018 9:43 pm
Can we use boost on ESP33. Does all boost libraries work on Esp32. Does it fit under 1MB Flash?
ogensyts
Postby ogensyts » Fri Jul 06, 2018 5:12 am
To answer your question snahmad75, no you cannot. To give one example, Boost uses a different threading system which is not compatible with ESP32's FreeRTOS. The project will not compile.
malachib
Postby malachib » Tue Aug 28, 2018 9:10 am
It's definitely not the same as boost, but I been working on 'estd' library, providing bits and pieces of std lib functionality and works on embedded targets.
Located https://github.com/malachi-iot/estdlib
Users browsing this forum: Barkrowler, Google [Bot], PerplexityBot, PetalBot and 2 guests
