How to configure BLE transmit output power classes
Duracell
Postby Duracell » Sun Oct 08, 2017 7:12 pm
Hi all
I am looking for a way to configure the BLE radio transmit output power to class 3 (range < 1m) for advertising packets.
According to the datasheet this should be possible.
I could not find any API to do this.
Anybody knows how to do this?
I already tried changing BTM_BLE_ADV_TX_POWER in bt_target.h but this had no effect.
Any help is greatly appreciated.
Dura
Duracell
Re: How to configure BLE transmit output power classes
Postby Duracell » Sat Oct 21, 2017 5:41 pm
This works now with the latest version from master.
There are new functions in bt.h:
 * @brief  Set BLE TX power
 *         Connection Tx power should only be set after connection created.
 * @param  power_type : The type of which tx power, could set Advertising/Connection/Default and etc
 * @param  power_level: Power level(index) corresponding to absolute value(dbm)
 * @return              ESP_OK - success, other - failed
esp_err_t esp_ble_tx_power_set(esp_ble_power_type_t power_type, esp_power_level_t power_level)
anandvilayil
why esp32 wroverchip limit bluetooth range around 2 meters?
Postby anandvilayil » Fri May 04, 2018 7:48 am
hii all
i am now dealing with esp32 gatt client program. in that my esp32 could not connecting to the gatt server(even it not found in scanning). then i flashed the ibeacon program in the examples to the esp32. later i scanned it from my phone, in range of 1.5 meter it showing in phone scanner. but if i exceed the range beyond 1.5 meter it not getting in my phone scanner. i am new to this esp32 world. will you please help me?. whether i should change anything in make menuconfig?.
some one please help me...
newsettler_AI
Re: why esp32 wroverchip limit bluetooth range around 2 meters?
Postby newsettler_AI » Mon May 21, 2018 4:17 pm
hii all
Hi, try to set tx value to 20 in SDK config -> Component config -> PHY config.
