One options for consideration is using Arduino as a component in an ESP32 ESP-IDF application ... see the following:
https://github.com/espressif/arduino-es ... mponent.md
Programming in C++ and using esp_wifi
Re: Programming in C++ and using esp_wifi
Mahmoud Omar
Thank you for the link.
I did everything and i get the following message in eclipse.
make[1]: *** No rule to make target 'C:/msys32/home/Mahmoud/esp/trial/main/main.c', needed by 'main.o'. Stop.
make: *** [C:\msys32\home\Mahmoud\esp\esp-idf/make/project.mk:467: component-main-build] Error 2
make: *** Waiting for unfinished jobs....Re: Programming in C++ and using esp_wifi
Ive seen a similar message when trying to rename main.c to main.cpp. For me, the result was to remove the local build directory and rebuild all and then it "magically" worked.
Mahmoud Omar
I did the steps in your creating C++ application and it worked with me. Thank you very much.
The thing is that i now have the ESPNOW code with arduino in C++ and i need to add SPI Slave code in the the same code.
the spi slave is in c and when the structs are initializing it returns
i removed the "." and replaced = with : and yet the same problem
How can i overcome this problem?
unimplemented: non-trivial designated initializers not supportedHow can i overcome this problem?
Mahmoud Omar
Also if there is a way to use the SPI slave code in arduino IDE it would be great.
because the only example i can find is for ESP8266 and it doesn't work with the ESP32.
Angus, Kolban,
thank you. very usefull discussion and information.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 1 guest
