ESP32 WebUpdate?
perigalacticon
ESP32 WebUpdate?
I am looking for an example sketch similar to WebUpdater.ino sketch for the ESP8266 that lets you upload a new sketch to a hosted webpage from a bin file on your computer. I haven't found it yet, does this sketch exist somewhere for the ESP32?
Re: ESP32 WebUpdate?
I saw an example some time ago for esp32 webupdate...
HERE i have a class implemented for this.
Take a look.
Will take 5 minutes to adapt the code to your needs.
Take a look.
1163167506
I once modified it by looking at Arduino esp32's own OTA upgrade program to WebUpdate, you need to know the way HTTP uploads files, several key points.
1.web uploads bin files through Content-Type: application/octet-stream mode
2. code
If (canBegin)
Serial.println ("111Error Occurred. Error:" + String (Update.getError ());
Size_t written = Update.writeStream (client); //wait write 1~3min
If (written = = contentLength) {
Serial.println ("Written:" + String (written) + "successfully");
Else
Serial.println ("Written only:" + String (written) + "/" + String (contentLength) + "Retry?";
/ / retry??
/ / execOTA ();
If (Update.end ())
Serial.println ("OTA done!");
If (Update.isFinished ())
Serial.println ("Update successfully completed. Rebooting.");
ESP.restart ();
Else
Serial.println ("Update not finished? Something went wrong!");
Else
Serial.println ("Error Occurred. Error:" + String (Update.getError ());
Else
Serial.println ("cat not begin");
2. code
If (canBegin)
Else
/ / retry??
/ / execOTA ();
If (Update.end ())
ESP.restart ();
Else
Else
Else
