I tried changing all the modes and changing the SPI bus speed. Still the same issue.
The board is based on the PICO-D4 reference design. I have left out the pull-up on IO12 to enable 3V3 operation.
I also dumped the fuses and I see that the SPI pins are already set.
I tried programming with both the Arduino IDE and the IDF and still the same issue.
Any suggestions would be appreciated.
I tried searching on the forum for any solutions but I don't see any fix.
esptool.py v2.3.1
Flashing binaries to serial port COM16 (app at offset 0x10000)...
esptool.py v2.3.1
Connecting.....
Chip is ESP32-PICO-D4 (revision 0)
Features: WiFi, BT, Dual Core, Embedded Flash
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0320
Compressed 23696 bytes to 13355...
Wrote 23696 bytes (13355 compressed) at 0x00001000 in 1.2 seconds (effective 161.8 kbit/s)...
Hash of data verified.
Compressed 457792 bytes to 303931...
Wrote 457792 bytes (303931 compressed) at 0x00010000 in 26.8 seconds (effective 136.7 kbit/s)...
Compressed 3072 bytes to 103...
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.0 seconds (effective 786.6 kbit/s)...
Leaving...
Hard resetting via RTS pin...
MONITOR
--- idf_monitor on COM16 115200 ---
ets Jun 8 2016 00:22:57
configsip: 188777542, SPIWP:0xee
mode:DOUT, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:7916
load:0x40078000,len:0
load:0x40078000,len:15684
entry 0x400786dc
entry 0x400786dc
entry 0x400786dc
espefuse.py v2.4.1-dev
Connecting....
Efuse fuses:
WR_DIS Efuse write disable mask = 0 R/W (0x0)
RD_DIS Efuse read disablemask = 0 R/W (0x0)
CODING_SCHEME Efuse variable block length scheme = 0 R/W (0x0)
KEY_STATUS Usage of efuse block 3 (reserved) = 0 R/W (0x0)
Security fuses:
FLASH_CRYPT_CNT Flash encryption mode counter = 0 R/W (0x0)
FLASH_CRYPT_CONFIG Flash encryption config (key tweak bits) = 0 R/W (0x0)
CONSOLE_DEBUG_DISABLE Disable ROM BASIC interpreter fallback = 1 R/W (0x1)
ABS_DONE_0 secure boot enabled for bootloader = 0 R/W (0x0)
ABS_DONE_1 secure boot abstract 1 locked = 0 R/W (0x0)
JTAG_DISABLE Disable JTAG = 0 R/W (0x0)
DISABLE_DL_ENCRYPT Disable flash encryption in UART bootloader = 0 R/W (0x0)
DISABLE_DL_DECRYPT Disable flash decryption in UART bootloader = 0 R/W (0x0)
DISABLE_DL_CACHE Disable flash cache in UART bootloader = 0 R/W (0x0)
BLK1 Flash encryption key
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLK2 Secure boot key
BLK3 Variable Block 3
Config fuses:
XPD_SDIO_FORCE Ignore MTDI pin (GPIO12) for VDD_SDIO on reset = 0 R/W (0x0)
XPD_SDIO_REG If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset = 0 R/W (0x0)
XPD_SDIO_TIEH If XPD_SDIO_FORCE & XPD_SDIO_REG, 1=3.3V 0=1.8V = 0 R/W (0x0)
SPI_PAD_CONFIG_CLK Override SD_CLK pad (GPIO6/SPICLK) = 6 R/W (0x6)
SPI_PAD_CONFIG_Q Override SD_DATA_0 pad (GPIO7/SPIQ) = 17 R/W (0x11)
SPI_PAD_CONFIG_D Override SD_DATA_1 pad (GPIO8/SPID) = 8 R/W (0x8)
SPI_PAD_CONFIG_HD Override SD_DATA_2 pad (GPIO9/SPIHD) = 11 R/W (0xb)
SPI_PAD_CONFIG_CS0 Override SD_CMD pad (GPIO11/SPICS0) = 16 R/W (0x10)
DISABLE_SDIO_HOST Disable SDIO host = 0 R/W (0x0)
Calibration fuses:
BLK3_PART_RESERVE BLOCK3 partially served for ADC calibration data = 0 R/W (0x0)
ADC_VREF Voltage reference calibration = 1100 R/W (0x0)
Identity fuses:
MAC MAC Address
= d8:a0:1d:40:e0:44 (CRC 90 OK) R/W
CHIP_VER_REV1 Silicon Revision 1 = 0 R/W (0x0)
CHIP_VERSION Reserved for future chip versions = 0 R/W (0x0)
CHIP_PACKAGE Chip package identifier = 5 R/W (0x5)
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V).--demi
