--- idf_monitor on COM14 115200 ---
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:5784
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:14032
entry 0x40078ff0
I (30) boot: ESP-IDF v3.0.1 2nd stage bootloader
I (30) boot: compile time 09:57:53
I (32) boot: Enabling RNG early entropy source...
I (34) qio_mode: Enabling QIO for flash chip GD
I (39) boot: SPI Speed : 80MHz
I (44) boot: SPI Mode : QIO
I (48) boot: SPI Flash Size : 8MB
I (52) boot: Partition Table:
I (55) boot: ## Label Usage Type ST Offset Length
I (62) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (70) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (77) boot: 2 factory factory app 00 00 00010000 00100000
I (85) boot: End of partition table
I (89) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x4385c (276572) map
I (171) esp_image: segment 1: paddr=0x00053884 vaddr=0x3ffb0000 size=0x03838 ( 14392) load
I (175) esp_image: segment 2: paddr=0x000570c4 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at C:/msys32/home/esp/esp-adf/esp-idf/components/freertos/xtensa_vectors
.S:1685
I (178) esp_image: segment 3: paddr=0x000574cc vaddr=0x40080400 size=0x08b44 ( 35652) load
I (198) esp_image: segment 4: paddr=0x00060018 vaddr=0x400d0018 size=0xfa4ac (1025196) map
0x400d0018: _flash_cache_start at ??:?
I (469) esp_image: segment 5: paddr=0x0015a4cc vaddr=0x40088f44 size=0x0896c ( 35180) load
0x40088f44: xTaskIncrementTick at C:/msys32/home/esp/esp-adf/esp-idf/components/freertos/tasks.c:4494
(discriminator 2)
I (480) esp_image: segment 6: paddr=0x00162e40 vaddr=0x400c0000 size=0x00000 ( 0) load
E (480) esp_image: Image length 1388144 doesn't fit in partition length 1048576
E (486) boot: Factory app partition is not bootable
E (491) boot: No bootable app partitions in the partition table
user code doneHow can I address this issue?
thank you.
