Hi All,
Anyone using PlatformIO? I welcome opinions, experience, Pros and cons for this platform.
[BEN]
Using PlatformIO?
- Vader_Mester
- Contact:
Using PlatformIO?
task_t coffeeTask()
while(atWork){
coffeeDrink(mug);
} else {
vTaskDelete(NULL);
}Re: Using PlatformIO?
I tried and hated it. When I switched to CMake it is so much better and so simple you cannot compare the convenience and speed
I mean Visual Studio Code + CMake build environment for ESP32 freeRTOS
I have been using platform IO for several months now. I am still on the fence with using it as compared to VSC & CMake.
I have not had any issues with it at all, and I like the ability to create a new project using either the Arduino framework or IDF.
I'll keep using both for now. The only downside I have seen with Platform IO is that (last I checked) when using Arduino you have no way to setup menuconfig.
Last time I checked PlatformIO does not work with FreeRTOS.
Did you manage to run and compile IDF projects in full RTOS environment or just Arduino?
I had quite some issues with Arduino as well
It should work fine, both for Arduino and ESP-IDFAnyone using PlatformIO? I welcome opinions, experience, Pros and cons for this platform.
As already noted, the major downside is that, for the time being, it is not possible to customize anything below Arduino.
What do you mean both ?
Arduino uses IDF and runs on top of RTOS )
IDF is written in FreeRTOS API. Arduino is just a framework for RTOS.
Check my setup guide posted here:
https://esp32.com/viewtopic.php?f=13&t=6383
It means you're able to use PlatformIO for either Arduino projects or ESP-IDF projects side-by-side in one single installation.What do you mean both ?
P.S.: I will have a look at your guide, it could happen that I find your way better than PIO, who knows!
Users browsing this forum: PerplexityBot and 4 guests
