Builds are too big and take too long?
Re: Builds are too big and take too long?
That's related to either bad PC - faulty hardware like ram or HD - or something wrong with IDF.
Make sure it is python 2.7 not 3
Also try running cmd.exe in separate window
xiaolongba
solved.as u can see in the picture,it is python2.7 not 3.the reason is the codepage of python2.7 is GBK,when i change the codepage to OEM-437 inThat's related to either bad PC - faulty hardware like ram or HD - or something wrong with IDF.
HKEY_CURRENT_USER\Consoleat last,thanks for your help.
xiaolongba
yes.thanks for your helpNice. So you are able to compile project?
xiaolongba
this method is also can work well.but the cmake idf is not bad.try make flash -j5
I'm glad to hear that) I'll try that option - thanks for hints
xiaolongba
btw.In fact, I have implemented vscode+bash to develop esp32 before, but I wrote it in Chinese. At the same time, the garbled problem has not been solved, and now these problems have been solved.the github addr as shown as belown:Nice. So you are able to compile project?
https://github.com/xiaolongba/wireless- ... 5%A2%83.md
Well I don't know how you guys are running menuconfig but the cleanest way I do that is :
if it is cmd.exe all compilation logs are staying in same window unlike with powershell but menuconfig fails because of column limit to display
- from Integrated terminal - by default terminal.integrated.shell.windows = cmd.exe (or powershell)powershell idf.py menuconfig
xiaolongba
u are right.I have encountered this problem.so i do it like thisWell I don't know how you guys are running menuconfig but the cleanest way I do that is :
G:\\Project\\esp32\\toolchain\\msys32\\mingw32.exe make menuconfigCode: Select all
powershell idf.py menuconfigWho is online
Users browsing this forum: Semrush [Bot] and 3 guests
