I'm tring to compile the examples and deploy it on my esp32-Wroom devkit, but I have problem during the compilation process (some adafruit.h not found)..
I would create a simple mesh network with 2 nodes.
Someone can help me?
Please.
Thanks in advance
Mesh network example
Re: Mesh network example
Could you run example/get-started/hello_world and other examples successfully?
See the document ESP-IDF Programming Guide.
https://docs.espressif.com/projects/esp ... et-esp-idf
I have compiled correctly and running the examples of esp32-idf where the Mesh examples require the router connection..
In this case, I would try the Mesh example provided in esp32-mdf, in which I have the compiler error reported previously.
