Is brownout detection usable now?
urbanze
Re: Is brownout detection usable now?
Postby urbanze » Wed Aug 22, 2018 5:58 pm
What is the maximum value can I get to trigger BOD? In menuconfig, maximum is ~2.7V (7<<bit) == (10000000), but whats happen if write (11111111)? I would like to get ~3V, this is possible?
WiFive
Postby WiFive » Wed Aug 22, 2018 9:44 pm
It is a 3 bit value so 7 is max
urbanze
Postby urbanze » Wed Aug 22, 2018 10:04 pm
Oh sorry, bodwait_reg is larger. My mistake. But if 7 is max, I should 3V is impossible... Thanks.
I testing my own isr to write some data in flash in case BOD trigger, but I think that nvs API is little slow. What API can I use to write in flash with velocity focus?
ESP_igrr
Postby ESP_igrr » Wed Aug 22, 2018 10:59 pm
When brownout is detected, it is very likely that reliable flash writes are already impossible (unless you have a 1.8V capable part). In fact, in many cases it is the flash chip that browns out first.
urbanze
Postby urbanze » Wed Aug 22, 2018 11:03 pm
:( Can you say any "internal" method to write data to avoid lost data in ram?
ESP_igrr
Postby ESP_igrr » Wed Aug 22, 2018 11:05 pm
Possibly RTC memory via RTC_NOINIT_ATTR, but it may be lost if the supply voltage drops below about 1V.
urbanze
Postby urbanze » Wed Aug 22, 2018 11:12 pm
Ya, this is my last ideia but with power off, all ram is lost. I will try tomorrow.
urbanze
Postby urbanze » Thu Aug 23, 2018 12:35 pm
I testing velocity of BOD comparator but with ~2.7V +- 0.05V make little hard to find specific latency.
What's the latency of BOD since threshold AND isr? In some PIC's is ~500ns + 2 cycles + X cycles to handle isr... And in esp32?
Users browsing this forum: ChatGPT-User, PerplexityBot, PetalBot and 4 guests
