EVK-NINA-W10 JTAG Debugger issue
Dmytro_Medvid
Postby Dmytro_Medvid » Wed Sep 12, 2018 6:36 am
I`m trying to launch debug session in Eclipse with OpenOCD. Error log is the next:
OpenOCD log:
Open On-Chip Debugger 0.10.0-dev (2018-07-24-09:39)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 100 kHz
esp32 interrupt mask on
Started by GNU ARM Eclipse
Info : clock speed 100 kHz
Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: Exception reading pc!
Info : Target halted. PRO_CPU: PC=0x00000000 (active)    APP_CPU: PC=0x00000000
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
embedded:startup.tcl:21: Error:
in procedure 'init'
in procedure 'ocd_bouncer'
in procedure 'esp_smp_break_config'
in procedure 'esp32' called at file "OpenOCD_CFG\esp32.cfg", line 54
in procedure 'esp_core_halt'
in procedure 'esp32' called at file "OpenOCD_CFG\esp32.cfg", line 44
at file "embedded:startup.tcl", line 21
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : cpu0: Failed reading 4 bytes at address 0x3FF00030
Error: Failed to read target memory (-4)!
cpu0: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
cpu1: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
Warn : cpu0: Failed reading 5880 bytes at address 0x40090000
Error: no working area available, can't alloc space for stub code!
Error: Failed to load stub (-308)!
Error: Algorithm run faied (-308)!
Error: Faied to run flasher stub (-308)!
Error: Failed to get flash mappings (-308)!
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Eclipse log:
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
Remote communication error.  Target disconnected.: No error.
Jumpers position:
Any ideas?
Re: EVK-NINA-W10 JTAG Debugger issue
Postby Sprite » Wed Sep 12, 2018 8:10 am
This usually indicates a connection problem between the jtag-interface and the ESP32. It can also occur if you reconfigure the GPIOs used for JTAG for something else in your program.
Dmytro_Medvid
Postby Dmytro_Medvid » Wed Sep 12, 2018 12:54 pm
The problem was in .cfg file for OpenOCD module. I`ve added next lines:
ftdi_layout_init 0x0008 0x000b
reset_config none
And all works now)
