Interfacing to SD card using 4bit SD mode
proprocks
Postby proprocks » Mon Jan 25, 2016 4:23 pm
The press releases for the ESP32 mention an SDIO peripheral, however I'm having difficulties finding out much more information than that. The most I've read is that the ESP31 is a SDIO slave device (ie. SDIO used for a host micro to talk to the ESP31), while the ESP32 would be a SDIO master device (SDIO used to talk to an SD card.) We're searching for a wifi module that can read/write to a SD card at a decent rate (SPI being too slow.)
Can anyone confirm how the ESP32's SDIO is/can be used?
iot-bits.com
Contact:
Re: Interfacing to SD card using 4bit SD mode
Postby iot-bits.com » Wed Dec 21, 2016 6:16 am
What is the speed that you could get using SPI interface with an SD Card? The ESP8266 easily managed around 10 Mbits/s with HSPI... so the ESP32 can do the same (SPI hardware is almost identical on both)
- Pratik
:geek: Just another hobbyist and consultant
Postby Sprite » Wed Dec 21, 2016 6:54 am
The SPI bus can be clocked at 80MHz, so 10MByte/s is the theoretical max. It can also do 4-bit parallel reads/writes, so with that it should be able to shift 40MByte/sec in theory. It has DMA, so as long as you keep the buffers filled, you should be able to get pretty close to that theoretical maximum.
iot-bits.com
Contact:
Postby iot-bits.com » Wed Dec 21, 2016 8:40 am
10M bits I meant. That's the max I could go. Over that, traditional SPI mode won't work as card has frequency limits of about 25MHz.
- Pratik
Users browsing this forum: ChatGPT-User, PerplexityBot, PetalBot, Semrush [Bot] and 7 guests
