POST replaces charactor "+" to charactor " " in Base64 encoded text
dinosauria123
Postby dinosauria123 » Tue Oct 23, 2018 6:14 am
I try to POST base64 encoded jpeg image from M5Camera to another server.
I could Base64 encode using by mbedtls_base64_encode(), it seems to be fine.
but I used POST method in esp_http_client_example.c in example of esp-idf,
POST replaces charactor "+" to charactor " " in Base64 encoded text.
How can I fix this problem ?
static void http_post_task(void *pvParameters)
        .url = "http://httpbin.org/get",
//        .event_handler = _http_event_handler,
   esp_http_client_handle_t client = esp_http_client_init(&config);
   esp_err_t err = esp_http_client_perform(client);
     unsigned char image0[30000];
     char image[30000];
     size_t olen;
     mbedtls_base64_encode(image0, sizeof(image0), &olen, camera_get_fb(), camera_get_data_size());
    static char *HEADER = "text=";
    snprintf(image, sizeof(image0)+5, "%s%s", HEADER, image0);
    const char *post_data = (const char*)image;
    esp_http_client_set_url(client, "http://httpbin.org/get/");
    esp_http_client_set_method(client, HTTP_METHOD_POST);
    esp_http_client_set_post_field(client, post_data, strlen(post_data));
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "HTTP POST Status = %d, content_length = %d",
                esp_http_client_get_status_code(client),
                esp_http_client_get_content_length(client));
    } else {
        ESP_LOGE(TAG, "HTTP POST request failed: %s", esp_err_to_name(err));
    while(1);
Re: POST replaces charactor "+" to charactor " " in Base64 encoded text
Postby Sprite » Wed Oct 24, 2018 2:12 am
My guess would be that you send the data as a form field; these normally are urlencoded, even in a POST.
