Auto flashing error (GPIO0 need to be manually set low)
newsettler_AI
Postby newsettler_AI » Wed Oct 24, 2018 9:44 am
Hello!
I'm using ESP32 DOIT kit. I flashed it automatically with onboard CP2102 usb-uart converter.
But once I got app crash (says CPU halted) I'm not available to flash it in auto mode.
Now I have to hold GPIO_0 on ground untill flashing will be done, even with fixed code its not flashing automatically anymore.
I cant get what happens, since there wasnt any hardware errors :shock:
How can I fix it?
anakyr
Re: Auto flashing error (GPIO0 need to be manually set low)
Postby anakyr » Wed Oct 24, 2018 11:54 am
Probably one of your two transistors is broken, that control the DTR RTS signals.
newsettler_AI
Postby newsettler_AI » Wed Oct 24, 2018 12:36 pm
but how can it be damaged with sofware problem? It was only some kind of hard fault...
