How to Visually Tell New from Old Silicon?
ESP_igrr
Re: How to Visually Tell New from Old Silicon?
Postby ESP_igrr » Tue Apr 25, 2017 11:28 am
The getChipRevision function in Arduino has a bug, by the way, as it has "&& EFUSE_RD_CHIP_VER_RESERVE_V" instead of "& EFUSE_RD_CHIP_VER_RESERVE_V". Also, the 8-bit EFUSE_RD_CHIP_VER_RESERVE field is used to encode a bunch of different things.
Lower 3 bits encode the package (0 = D0WDQ6, 1 = D0WDQ5, 2 = D2WDQ5), next 4 bits are reserved, the MSB is used for silicon version (0 = rev0, 1 = rev1).
We will have a function to check the chip revision/package in IDF soon and the updated efuse_reg.h file with these bit fields.
Postby rudi ;-) » Tue Apr 25, 2017 11:34 am
Ah, thank you Ivan,
now we get some more "new" details
we can test if the parcel delivery earliest next week ;) ....
btw "new" details:
Who always keeps such information back to the end,
The silicon vallery, the manufacturer, the developer, the "discoverer" .....
love this "Salami tactics" :mrgreen:
ikerbelloso
Postby ikerbelloso » Tue Apr 25, 2017 11:40 am
Thank you to both
BuddyCasino
Postby BuddyCasino » Tue Apr 25, 2017 12:08 pm
Saw that piece of code being used in a driver, so I guess they are confident the method itself (which is similar to what rudi posted) works:
uint32_t is_rev0 = (GET_PERI_REG_BITS2(EFUSE_BLK0_RDATA3_REG, 1, 15) == 0);
Source: https://github.com/espressif/esp-idf/bl ... clk.c#L133
Postby rudi ;-) » Tue Apr 25, 2017 4:22 pm
The getChipRevision function in Arduino has a bug, by the way, as it has "&& EFUSE_RD_CHIP_VER_RESERVE_V" instead of "& EFUSE_RD_CHIP_VER_RESERVE_V". ....
btw: LoL
https://github.com/espressif/arduino-es ... p.cpp#L120
uint8_t EspClass::getChipRevision(void)
    return (REG_READ(EFUSE_BLK0_RDATA3_REG) >> EFUSE_RD_CHIP_VER_RESERVE_S) && EFUSE_RD_CHIP_VER_RESERVE_V;
https://github.com/loboris/Lua-RTOS-ESP ... /cpu.c#L98
int cpu_revission() {
Interesting
One writes the same "error" from the other :)
More Interesting:
@Mike
the snippet code read register comes in esp-idf in past 14 days ( 2017 April 11 )
https://github.com/espressif/esp-idf/co ... b9e4abR133
the arduino got this "error" version on 2017 Feb 23 by "third party"
- added function to retrieve chip revision from eFuse
https://github.com/espressif/arduino-es ... 32/Esp.cpp
testato
Postby testato » Sat Oct 07, 2017 4:49 am
I pushed a PR
https://github.com/espressif/arduino-esp32/pull/704
May the efuse be changed ?
I mean, can a fraudolent seller change the efuse bit and so sell old rev 0 for a rev 1 ?
kolban
Postby kolban » Mon Oct 16, 2017 4:12 am
Reading through exposed APIs, I seem to find an ESP-IDF API called "esp_chip_info" which now reports a variety of items include:
* model
* features
* number of cores
* revision
I believe the revision fields is the silicon revision described in this post. This is a high level API and is probably more consumable that some of the other bit twiddlings.
pataga
Postby pataga » Sun Nov 12, 2017 6:34 am
I purchased a WROOM32 module a month ago after reading some reviews from buyers that mentioned they had received a rev 1 chip.
Looking for code to check the revision, I found Arduino code on instructables (and the same in a youtube video series on the ESP32)
http://www.instructables.com/id/How-to- ... our-ESP32/
int getChipRevision()
  return (REG_READ(EFUSE_BLK0_RDATA3_REG) >> (EFUSE_RD_CHIP_VER_RESERVE_S)&&EFUSE_RD_CHIP_VER_RESERVE_V) ;
I run this and it returns a chip revision of 0. Am pissed off, but then see that the code is obviously wrong - it's using a logical && instead of a bitmask &.
RTFM right ? So I downloaded the latest TRM and in Table 64, I see that the bitfield chip_version is in bits 12:9 of register EFUSE_BLK0_RDATA3_REG
So I run my own arduino code
#include "soc/efuse_reg.h"
void setup() {
  Serial.begin(115200);
  uint32_t reg =  REG_READ(EFUSE_BLK0_RDATA3_REG);
  Serial.printf("\r\nEFUSE_BLK0_RDATA3_REG = %08X\r\n", reg );
  uint8_t chipRevision = (uint8_t)((REG_READ(EFUSE_BLK0_RDATA3_REG) >> 9 ) & 0x0F);
  Serial.printf("Chip revision = %X\r\n"  , chipRevision );
void loop() {
which gives me
EFUSE_BLK0_RDATA3_REG = 00008000
Chip revision = 0
Still pissed off that I have a rev 0 chip. But I then find this page
https://github.com/espressif/esptool/issues/206
and on running 'python espefuse.py -p COM4 summary' I get the result
CHIP_VERSION           Chip version                                      = 8 R/W (0x8)
CHIP_PACKAGE           Chip package identifier                           = 0 R/W (0x0)
which tells me (phew) that I do have a ESP32-D0WDQ6 silicon revision 1 chip.
On running espefuse.py with a WROOM32 module I purchased last year, I found that it is a revision 0 chip, and my code returns
EFUSE_BLK0_RDATA3_REG = 00000000
Chip revision = 0
So i'm guessing the chip_version bitfield is bit 15:12, not 12:9
sshaikh
Postby sshaikh » Thu Jul 19, 2018 5:13 pm
For those who might be confused (like I was), here are the respective expected outputs as of 19th July 2018. Unfortunately I don't have a v0 chip to compare, but I presume the below all indicate that mine is a v1.
From instructables, after using the new shift globals:
  return (REG_READ(EFUSE_BLK0_RDATA3_REG) >> (EFUSE_CHIP_VER_REV1_S)&&EFUSE_CHIP_VER_REV1_V) ;
result:
REG_READ(EFUSE_BLK0_RDATA3_REG) 1010000000000000
EFUSE_CHIP_VER_REV1_S 1111
EFUSE_CHIP_VER_REV1_V 1
Chip Revision (official version): 1
Chip Revision from shift Opration 1
From espefuse.py:
Identity fuses:
MAC                    MAC Address
  = aa:aa:aa:aa:aa:aa (CRC 23 OK) R/W
CHIP_VER_REV1          Silicon Revision 1                                = 1 R/W (0x1)
CHIP_VERSION           Reserved for future chip versions                 = 2 R/W (0x2)
From esptool.py chip_info:
esptool.py v2.5.0
Serial port COM3
Connecting........__
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse
MAC: aa:aa:aa:aa:aa:aa
Uploading stub...
Running stub...
Stub running...
Warning: ESP32 has no Chip ID. Reading MAC instead.
Hard resetting via RTS pin...
testato
Postby testato » Thu Oct 25, 2018 7:13 pm
* model
* features
* number of cores
* revision
yep, the actually merged function use this method, so now the getChipRevision() return the correct hw revision
