As the topic, I wanna get finest ticks from the system. Currently I can get ticks from FreeRTOS but resolution is not enough. I wonder that we can get something like 'Execution tick count' by some ways.
Thank you!
How the most finest 'tick count' I can get from ESP32 ?
gearwalker
Re: How the most finest 'tick count' I can get from ESP32 ?
1. gettimeofday function. With default settings in menuconfig, gives you time at microsecond resolution. Timekeeping continues in deepsleep (but there is a bug in the current master branch which causes time to be reset when going to deep sleep; follow above link for a workaround).
2. CCOUNT CPU register (one on each CPU). Gives you number of CPU cycles since CPU has started. Counts ticks, so doesn't account for CPU frequency changes (not a problem now, but may be once we implement D(V)FS). Counters of the two CPUs are not synchronized in any way, so take care if your task has no CPU affinity.
#include "xtensa/core-macros.h"
uint32_t ccount = XTHAL_GET_CCOUNT();
gearwalker
Users browsing this forum: Applebot, Bing [Bot], Google [Bot] and 3 guests
