Greetings,
If someone needs it - I've got a successful connection with eduroam, but there are few limitations:
- This code runs with the newest development Framework code 3.1 / 3.2 (beta),
- Paste your Certificate in
array,
- Fill code (or create a remote .h file) with your credentials,
- You have to wait a little bit to connect,
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_wifi.h"
#include "esp_wpa2.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "tcpip_adapter.h"
#define EXAMPLE_WIFI_SSID "eduroam"
#define EXAMPLE_EAP_METHOD EAP_PEAP
#define EXAMPLE_EAP_ID ""
#define EXAMPLE_EAP_USERNAME "login@university"
#define EXAMPLE_EAP_PASSWORD "PASSWORD"
static EventGroupHandle_t wifi_event_group;
const int CONNECTED_BIT = BIT0;
/* Constants that aren't configurable in menuconfig */
#define EAP_PEAP 1
#define EAP_TTLS 2
// You may change it
static const char *TAG = "test";
//HERE YOU MAKE Ctrl+C Ctrl+V OF YOUR UNIVERSITY CERTIFICATE
const char *ca_pem = "Certificate:\n"\
"-----END CERTIFICATE-----\n";
static esp_err_t event_handler(void *ctx, system_event_t *event)
switch(event->event_id) {
case SYSTEM_EVENT_STA_START:
esp_wifi_connect();
break;
case SYSTEM_EVENT_STA_GOT_IP:
xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
break;
case SYSTEM_EVENT_STA_DISCONNECTED:
esp_wifi_connect();
xEventGroupClearBits(wifi_event_group, CONNECTED_BIT);
break;
default:
break;
return ESP_OK;
static void initialise_wifi(void)
esp_wpa2_config_t config = WPA2_CONFIG_INIT_DEFAULT();
tcpip_adapter_init();
wifi_event_group = xEventGroupCreate();
ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK( esp_wifi_init(&cfg) );
ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
wifi_config_t wifi_config = {
.sta = {
.ssid = EXAMPLE_WIFI_SSID,
ESP_LOGI(TAG, "Setting WiFi configuration SSID %s...", wifi_config.sta.ssid);
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK( esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
ESP_ERROR_CHECK( esp_wifi_sta_wpa2_ent_set_ca_cert((uint8_t *)ca_pem, strlen(ca_pem)) );
//DON'T USE - DON'T NEED
// ESP_ERROR_CHECK( esp_wifi_sta_wpa2_ent_set_cert_key(client_crt_start, client_crt_bytes, client_key_start, client_key_bytes, NULL, 0) );
// ESP_ERROR_CHECK( esp_wifi_sta_wpa2_ent_set_identity((uint8_t *)EXAMPLE_EAP_ID, strlen(EXAMPLE_EAP_ID)) );
if (EXAMPLE_EAP_METHOD == EAP_PEAP || EXAMPLE_EAP_METHOD == EAP_TTLS) {
ESP_ERROR_CHECK( esp_wifi_sta_wpa2_ent_set_username((uint8_t *)EXAMPLE_EAP_USERNAME, strlen(EXAMPLE_EAP_USERNAME)) );
ESP_ERROR_CHECK( esp_wifi_sta_wpa2_ent_set_password((uint8_t *)EXAMPLE_EAP_PASSWORD, strlen(EXAMPLE_EAP_PASSWORD)) );
ESP_ERROR_CHECK( esp_wifi_sta_wpa2_ent_enable(&config) );
ESP_ERROR_CHECK( esp_wifi_start() );
static void wpa2_enterprise_example_task(void *pvParameters)
tcpip_adapter_ip_info_t ip;
memset(&ip, 0, sizeof(tcpip_adapter_ip_info_t));
vTaskDelay(2000 / portTICK_PERIOD_MS);
while (1) {
if (tcpip_adapter_get_ip_info(ESP_IF_WIFI_STA, &ip) == 0) {
ESP_LOGI(TAG, "~~~~~~~~~~~");
ESP_LOGI(TAG, "IP:"IPSTR, IP2STR(&ip.ip));
ESP_LOGI(TAG, "MASK:"IPSTR, IP2STR(&ip.netmask));
ESP_LOGI(TAG, "GW:"IPSTR, IP2STR(&ip.gw));
void app_main()
ESP_ERROR_CHECK( nvs_flash_init() );
initialise_wifi();
xTaskCreate(&wpa2_enterprise_example_task, "wpa2_enterprise_example_task", 4096, NULL, 5, NULL);
Regards,
and good luck
