cannot open linker script file
Patrik Celin
Postby Patrik Celin » Tue Nov 27, 2018 2:07 pm
I've upgrade ESP-IDF from v.3.2-beta1 to v.3.3-dev and I've got an error with the linker also with hello-world example:
"linker script generation failed for /esp-idf/components/esp32/ld/esp32.commonld.in
ERROR:
LD build/hello-world.elf
/../../../xtensa-esp32-elf/bin/ld:
cannot open linker script file /esp/hello_world/build/esp32.common.ld: No such file or directory
collect2: error: ld returned 1 exit status"
Some idea?
Best Regards
ESP_igrr
Re: cannot open linker script file
Postby ESP_igrr » Tue Nov 27, 2018 2:42 pm
Could you please run 'make list-components' and paste the output?
Patrik Celin
Postby Patrik Celin » Tue Nov 27, 2018 2:53 pm
Sure!
out.txt
(2.88 KiB) Downloaded 1012 times
gigijoe
Postby gigijoe » Wed Nov 28, 2018 9:42 am
I'm facing exactly the same problem ...
MindReader32
Postby MindReader32 » Wed Nov 28, 2018 10:55 am
I'm also facing exactly the same issue with fa59b1b1c9e9085dde5fb2bbc7610bbdb2289741
I've attach an edited version of make list-components. It has my projects components and pathnames omitted for NDA reasons.
out.txt
(3.8 KiB) Downloaded 1000 times
Angus
Postby Angus » Mon Dec 03, 2018 4:24 am
Hi all,
Please update to the latest master branch. We've fixed some ldgen linker script generation issues, but also improved the error messages so if still fails there should be more information given about why.
Angus
Patrik Celin
Postby Patrik Celin » Fri Dec 07, 2018 9:33 am
Ok, with the last release of the master is fixed.
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 7 guests
