Esp32 433mhz communication
meneldor
Postby meneldor » Mon Dec 03, 2018 6:59 am
I am searching for any solution but can't find anything usable. I have an attiny chip which will measure surface temperature of a device in my backyard. I have some FS1000A 433mhz pairs which operates on 5v.
I want to send temp measurements from the attiny to a esp32 node located 20 meters away. The problem is i can't find any lib/project using such low cost receivers. I only found one for arduino-esp32 bit im stick to ESP-IDF. Also, FS1000A operates on 5V.
Could you please give me an advice? I'm not familiar with all the wireless communication variants so it could be any other low cost and low power consuming transmitter because the attiny node will be battery powered.
Thanks!
PeterR
Re: Esp32 433mhz communication
Postby PeterR » Mon Dec 03, 2018 10:18 am
https://dronebotworkshop.com/433mhz-rf-modules-arduino/
433 Mhz is simple enough and there seem to be quite a lot of arduino projects to learn from.
You will need to add voltage level shifters to convert between 3.3V and 5V.
meneldor
Postby meneldor » Mon Dec 03, 2018 10:42 am
Thank you, but im not interested in arduino. I know there are tons of examples/tutorials for it. I am looking for ESP-IDF lib or example.
PeterR
Postby PeterR » Mon Dec 03, 2018 12:25 pm
Maybe https://github.com/DominikPalo/esp32-rf-receiver ??
Not tried it.
Or I guess that the ESP-IDF RMT module would do it, you would need to know something about the bit lengths and its not fully packaged for you but not much code.
meneldor
Postby meneldor » Mon Dec 03, 2018 12:53 pm
Thanks, Peter, I will check them.
Deouss
Postby Deouss » Mon Dec 03, 2018 2:41 pm
I am working on 315mhz/433mhz project which involves replacing broken remote control of roof and gate openers.
What I would use is cheap 433mhz receiver controlled by esp RMT with no carrier enabled like FS1000A.
Also FS1000A only needs 5V vcc and not necessarily data signal.
I just managed to hack the signals using very cheap sdr dongle and universal radio hacker soft)
good luck
meneldor
Postby meneldor » Mon Dec 03, 2018 2:51 pm
Sorry, i wasn't clear. Im mostly interested in the receiver XD RF 5V, but i could use any other.
Deouss
Postby Deouss » Mon Dec 03, 2018 3:08 pm
Like this ? :
https://www.amazon.com/XD-RF-5V-Wireles ... B00PC9KVGC
meneldor
Postby meneldor » Mon Dec 03, 2018 3:22 pm
PeterR
Postby PeterR » Tue Dec 04, 2018 11:46 am
Your part needs 5.0V for RX. The ESP32 will RX your temperature sensor.
You may get away with 5.0V directly into the ESP. I have been running 5V SPI logic direct to ESP32 on a system I have been bread boarding (was lazy & did not want to wire a level shifter).
Works fine but probably will die one day.
Your RX signal would be low frequency so you could just use a divider https://randomnerdtutorials.com/how-to- ... v-to-3-3v/
Deouss is right - the IDF RMT module with no carrier should work for you. You would have to decide on the bit lengths and set filtering as appropriate but I think that may even be easier than the IDF library I pointed you at.
Users browsing this forum: PerplexityBot, Qwantbot, YisouSpider and 2 guests
