is it possible to use espnow.h to send sensor value from esp8266 to esp32?
tnks
esp8266 to esp32 with espnow.h
Re: esp8266 to esp32 with espnow.h
Hi all,
Im trying this example code https://github.com/leonyuhanov/ESP-NOW-TX-RX
uploading and running this sketch on esp8266 tx side: https://github.com/leonyuhanov/ESP-NOW- ... smiter.ino
and this is the serial monitor tx side (esp8266) output:
... and this sketch on the rx side (esp32): https://github.com/leonyuhanov/ESP-NOW- ... ceiver.ino
with tis output on serial moritor:
I'm a super newbi and I don't understand why data are not passing.....
any idea?
help please !!!
best regards
#include <ESP8266WiFi.h>
extern "C" {
#include <espnow.h>
#define WIFI_CHANNEL 1
//MAC ADDRESS OF THE DEVICE YOU ARE SENDING TO
//byte remoteMac[] = {0x36, 0x33, 0x33, 0x33, 0x33, 0x33};
byte remoteMac[] = {0x80, 0x7D, 0x3A, 0xDC, 0xB3, 0x95};
const byte dataLength=7;
byte cnt=0;
byte rcvData[dataLength];
byte result;
void setup()
Serial.begin(115200);
WiFi.mode(WIFI_STA);
WiFi.begin();
Serial.print("\r\n\r\nDevice MAC: ");
Serial.println(WiFi.macAddress());
Serial.println("\r\nESP_Now Controller.");
esp_now_init();
delay(10);
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
esp_now_add_peer(remoteMac, ESP_NOW_ROLE_COMBO, WIFI_CHANNEL, NULL, 0);
void loop()
for(cnt=0; cnt<dataLength; cnt++)
rcvData[cnt]++;
result = esp_now_send(remoteMac, rcvData, dataLength);
Serial.println(result);
delay(100);
}Code: Select all
Device MAC: 60:01:94:29:DC:D7
ESP_Now Controller.
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Compiled for the NODEMCU-32S
#include <esp_now.h>
#include <WiFi.h>
//uint8_t localCustomMac[] = {0x36, 0x33, 0x33, 0x33, 0x33, 0x33};
uint8_t localCustomMac[] = {0x80, 0x7D, 0x3A, 0xDC, 0xB3, 0x95};
//80:7D:3A:DC:B3:95
const byte maxDataFrameSize = 100;
byte cnt=0;
void setup()
Serial.print("\r\n\r\n");
WiFi.mode(WIFI_AP);
Serial.println( WiFi.softAPmacAddress() );
WiFi.disconnect();
if(esp_now_init() == ESP_OK)
Serial.println("ESPNow Init Success!");
else
Serial.println("ESPNow Init Failed....");
esp_now_register_recv_cb(OnDataRecv);
void loop()
yield();
void OnDataRecv(const uint8_t *mac_addr, const uint8_t *data, int data_len)
Serial.printf("\r\nReceived\t%d Bytes\t%d", data_len, data[0]);
}Code: Select all
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load:0x40078000,len:9220
load:0x40080400,len:6300
entry 0x400806a4
80:7D:3A:DC:B3:95
any idea?
help please !!!
best regards
