Hi All,
I came across the scenario like, setting up 20+ client in AP+STA mode, if Active scan is done by one node, in result not getting info of all APs.
Using esp_wifi_scan_start API. API fail to get info of all 20+ clients in once scan event.
How to achieve successful case in this case, without failing?
Thank You,
Ankit Siddhapura
ESP32 WiFi : esp_wifi_scan_start fail
Re: ESP32 WiFi : esp_wifi_scan_start fail
Hi Ankit,
Would you please share few more details like which ESP32 IDF you are using?
Also please explain issue in details with step by step including failing logs as well
Regards,
Ritesh Prajapati
Ritesh Prajapati
I am using esp-idf v3.1 as well in older version 3.0rc1 seen same issue.
To choose best parent according to AP RSSI value, need AP info of all surrounded AP.
Waiting for the event SYSTEM_EVENT_SCAN_DONE to get result of scan process. This case is generated when other application task is running. Interval of scan is 1 minuet.
Regards,
Ankit Siddhapura
wifi_scan_config_t scanConf;
esp_wifi_scan_start(&scanConf, true);
Regards,
Ankit Siddhapura
Hi Espressif System SDK team,
I am working with Ankit regarding this support. So, Would you please check issue reported by him as i didn't get much time to see issue into depth for that.
So, Please let him know if you have any further query or need anything else regarding same.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Bytespider, Semrush [Bot] and 2 guests
