First I do signed of my partition then I encrypt it.
espsecure.py encrypt_flash_data --keyfile encryption_key.bin --address 0x8000 -o ./build/partitions-encrypted.bin ./build/signed_partitions.bin
espsecure.py v2.6-beta1
Using 256-bit key
WARNING: Padding with 12 bytes of random data (encrypted data must be multiple of 16 bytes long)
What this means?
Thanks,
Naeem
Re: WARNING: Padding with 12 bytes of random data (encrypted data must be multiple of 16 bytes long)
probably that data is encrypted in blocks of 16bytes. When the warning comes up it is encrypting something that is not a multiple of 16bytes, here you have a remainder of 4 bytes. this is why a random padding is added with a length of 12 bytes ( 4bytes data + 12 bytes padding = 1 block of 16bytes).
Yes, that's what it means.
You can ignore this warning, it should probably just say "note" instead.
EDIT: Have updated to esptool to say "note" as of the next release.
Angus
Angus
