system_get_rtc_time()
Postby rudi ;-) » Tue Jan 03, 2017 9:30 pm
hi guys
happy new year!
test the system_get_rtc_time(void) in
time.c ( newlib )
https://github.com/espressif/esp-idf/bl ... ime.c#L203
uint64_t system_get_rtc_time(void)
in kolban's esp32 book i read the function
*edit spelling*
with include esp_system.h
system_get_rtc_time
Get the real time clock cycles.
uint32_t system_get_rtc_time()
Page 372
Page 373
Retrieve the number of real-time clock cycles. For example, if the value returned by
system_rtc_clock_cali_proc() is 5.75µS then if the system_get_rtc_time() returns
100, then 575µS of wall clock time has passed since the clock was started.
Includes:
• esp_system.h
uint32_t system_get_rtc_time(void)
but there is no function in the system
https://github.com/espressif/esp-idf/bl ... p_system.h
same, there is no declare in the newlib/include/time.h
https://github.com/espressif/esp-idf/bl ... ude/time.h
do we miss / do we wrong here a part?
txs
kolban
Re: system_get_rtc_time()
Postby kolban » Tue Jan 03, 2017 11:39 pm
Howdy Rudi,
Good catch my friend ... there "used" to be a definition in esp_system.h that was removed here:
https://github.com/espressif/esp-idf/co ... 9396a8625e
and there is now an implemented function in newlib/time.c but no obvious header definition ... awesome find.
I'd suggest you go ahead and create an issue to resolve.
Postby rudi ;-) » Wed Jan 04, 2017 12:23 am
Howdy Rudi,
cheers Neil,
must check 'get_rtc_time_us' in the newlib/time.c too,
https://github.com/espressif/esp-idf/bl ... time.c#L44
static uint64_t get_rtc_time_us()
    SET_PERI_REG_MASK(RTC_CNTL_TIME_UPDATE_REG, RTC_CNTL_TIME_UPDATE_M);
    while (GET_PERI_REG_MASK(RTC_CNTL_TIME_UPDATE_REG, RTC_CNTL_TIME_VALID_M) == 0) {
    CLEAR_PERI_REG_MASK(RTC_CNTL_TIME_UPDATE_REG, RTC_CNTL_TIME_UPDATE_M);
    uint64_t low = READ_PERI_REG(RTC_CNTL_TIME0_REG);
    uint64_t high = READ_PERI_REG(RTC_CNTL_TIME1_REG);
    uint64_t ticks = (high << 32) | low;
    return ticks * 100 / (RTC_CTNL_SLOWCLK_FREQ / 10000);    // scale RTC_CTNL_SLOWCLK_FREQ to avoid overflow
first step, "system_get_rtc_time()" Issue created:
https://github.com/espressif/esp-idf/issues/196
igrr
Postby igrr » Wed Jan 04, 2017 12:36 am
This function was intentionally removed, as the functionality is now provided by POSIX gettimeofday function.
Postby rudi ;-) » Wed Jan 04, 2017 1:38 pm
Hi Ivan,
txs, how we can manage this "better" -
have searched long for find out this "system_get_rtc_time()" that is not present anymore time :D
ok - no problem - have changed my code snip like this now:
@Neil think you must update the kapitel in the ESP32 book too :mrgreen:
#include "time.h"
#include <sys/time.h>                   /* gettimeofday(), settimeofday() */
time_t now()
struct timeval tv = { .tv_sec = 0, .tv_usec = 0 };   /* btw settimeofday() is helpfull here too*/
// uint64_t sec, us;
uint32_t sec, us;
         gettimeofday(&tv, NULL);
         (sec) = tv.tv_sec;
         (us) = tv.tv_usec;
return sec;
Users browsing this forum: Applebot and 2 guests
