ESP32 OTA with encrypted firmware
hoainguyen265
Postby hoainguyen265 » Fri Dec 28, 2018 8:48 am
https://docs.espressif.com/projects/esp ... ption.html
In ESP document for flash encryption i found
OTA updates to encrypted partitions will automatically write encrypted, as long as the esp_partition_write function is used.
And in
esp_ota_write
we use
esp_partition_write
It mean the firmware ota is must be plaintext firmware.
But i want to do ota with encrypted firmware. This is a requirement for production.
Based on IDF document, i think i have to modified
esp_partition_write
for write unencrypted data.
Is there any solution for this?
I also looking for ESP32 production guide.
jcsbanks
Re: ESP32 OTA with encrypted firmware
Postby jcsbanks » Fri Dec 28, 2018 11:44 am
If you use https to fetch the firmware, and authenticate the ESP32, would that be a solution? This is what I am planning, to solve what sounds like a similar problem.
An alternative would be to encrypt the firmware to the individual device before sending it, will find and post the link...
Ritesh
Contact:
Postby Ritesh » Fri Dec 28, 2018 6:26 pm
And in
esp_ota_write
we use
esp_partition_write
esp_partition_write
Why you want OTA Firmware at time of production time? Because I believe you will just flash firmware using ESP32 tool at time of production and then user will update firmware using OTA based on requirements into device.
But it will be good to have encrypted firmware because of security.
Regards,
Ritesh Prajapati
Users browsing this forum: Amazon [Bot], ChatGPT-User, PerplexityBot and 18 guests
