MSYS2 is slow on Windows 10
Re: MSYS2 is slow on Windows 10
All you have to do in windows when using MSYS2 is slap "-jx" on the end of your make command. Where x is the number of processor cores you have. I have an 8 core system. so my make line is make -j8 flash.
@mikemoy: The option -jx I know already. This was not the question.
My question is that I am not able to quit the monitor mode (incoked by 'make monitor') using "Ctrl+]" key. This keystroke is simply ignored by WSL.
"Whoever believes to be someone has stopped becoming someone"
Sokrates
Sokrates
@squonk11, I was replying to the OP question of "If someone have a idea of how to speed up msys2 ..."
ah, o.k. Sorry for the misunderstanding.
But I am really having a problem with this right now: even starting the terminal mode (make monitor) takes sometimes several minutes until I see the first output on my screen.
Sokrates
Sokrates
Now I switched to the CMake build system under Windows cmd.exe. This works tremendously fast! But I still have the problem, that I am not able to quit monitor mode by hitting "Ctrl-]". But in windows cmd.exe I have the option to exit the running script (idf.py) just by hitting "Ctrl+c". This is not the "nice" way to work but for me this is currently the solution.
Sokrates
Sokrates
Great, I'm glad the CMake build system helped.Now I switched to the CMake build system under Windows cmd.exe. This works tremendously fast! But I still have the problem, that I am not able to quit monitor mode by hitting "Ctrl-]". But in windows cmd.exe I have the option to exit the running script (idf.py) just by hitting "Ctrl+c". This is not the "nice" way to work but for me this is currently the solution.
I'm not able to reproduce the Ctrl-] problem on my Windows development box. When I run "idf.py monitor", I see output as follows:
Executing "C:\Python27\python.exe C:\Users\gus\dev\esp-idf\tools/idf_monitor.py -p COM6 -b 115200 C:\Users\gus\Desktop\esp-idf-v3.1.2\examples\get-started\hello_world\build\hello-world.elf -m 'C:\Python27\python.exe' 'C:\Users\gus\Desktop\esp-idf-v3.1.2\tools\idf.py' '-p' 'COM6'"...
--- idf_monitor on COM6 115200 ---
My guesses are:
- This is an issue with some particular Python executable version, or idf.py thinks it's running under MSYS for some reason (and does a bunch of additional winpty emulation).
- This is something with keyboard layout or language settings, where Python is seeing a different control code for Ctrl-].
Hello squonk11!My question is that I am not able to quit the monitor mode (incoked by 'make monitor') using "Ctrl+]" key. This keystroke is simply ignored by WSL.
What is the IDF version you are using? I fixed a similar issue in https://github.com/espressif/esp-idf/co ... 8d36bfb1c9. Does this fix your issue?
@roland:
I am using:"v3.3-beta1-136-g97eecfa1b".What is the IDF version you are using?
I need to check if this also helps for me.I fixed a similar issue in https://github.com/espressif/esp-idf/co ... 8d36bfb1c9. Does this fix your issue?
Sokrates
Sokrates
@ESP_Angus
That looks quite similar to yours, right?
My output is:Python in this case is the standard Windows Python 2.7 install. Can you compare with the output you see from idf.py?Code: Select all
Executing "C:\Python27\python.exe C:\Users\gus\dev\esp-idf\tools/idf_monitor.py -p COM6 -b 115200 C:\Users\gus\Desktop\esp-idf-v3.1.2\examples\get-started\hello_world\build\hello-world.elf -m 'C:\Python27\python.exe' 'C:\Users\gus\Desktop\esp-idf-v3.1.2\tools\idf.py' '-p' 'COM6'"... --- idf_monitor on COM6 115200 ---
Executing "C:\Python27\python.exe C:\Users\xxxx\esp\esp-idf\tools/idf_monitor.py -p COM11 -b 115200 C:\Users\xxxx\esp\hello_world\build\hello-world.elf -m 'C:\Python27\python.exe' 'C:\Users\xxxx\esp\esp-idf\tools\idf.py' '-p' 'COM11'"..."Whoever believes to be someone has stopped becoming someone"
Sokrates
Sokrates
@roland
This fix is already included in my version of "idf.py". The problem still persits. But it is not a big issue since I can terminate monitor mode by Ctrl-c.Hello squonk11!
Sokrates
Sokrates
Users browsing this forum: Amazon [Bot], Baidu [Spider], ChatGPT-User, Semrush [Bot] and 2 guests
