I have been searching for a library that will mirror text on an OLED display so that when I try to read the text on the screen from a mirror, it will appear the right way around, i.e. I can read the text on the screen when I look at it through a mirror but will appear flipped on the screen itself.
I haven't been able to find a library to do this or I probably haven't explored existing libraries enough but im thinking of creating my own library to allow me to do this. I am using an ESP32 chip and an SSD1306 64x32 px display running over i2c. Im looking for some help since I'm a beginner and I've never made a library for any chips from Espressif.
any help will be much appreciated
Writing a custom library to mirror/flip text on an SSD1306 OLED display
Re: Writing a custom library to mirror/flip text on an SSD1301 OLED display
Also know that it's usually trivial to modify an existing library to either write the pixels mirrored, or change a register setting in the oled controller so the display does the mirroring all by itself. No need to search for a dedicated library for that.
Do I install this from the preferences menu in the Arduino IDE?How about this one ?
https://github.com/espressif/esp-iot-so ... rs/ssd1306
That would be really useful, im worried using another library in my code will cause compatibility issues. How do you suggest I go about changing a setting in the register, is there a guide online? I havent been able to find one on youtube and the datasheets for the display dont explicitly mention the ability to mirror text.Also know that it's usually trivial to modify an existing library to either write the pixels mirrored, or change a register setting in the oled controller so the display does the mirroring all by itself. No need to search for a dedicated library for that.
I just checked the SSD1301 datasheet; it's actually one of the few controllers that does not have a register setting for this, sorry.
my bad, I actually meant 1306 i believe its called "segment re-map" but I dont know how to actually change the register settingI just checked the SSD1301 datasheet; it's actually one of the few controllers that does not have a register setting for this, sorry.
Re: Writing a custom library to mirror/flip text on an SSD1306 OLED display
Ive found a solution, turns out it was in the library I was using already, just had to find all the commands and mix "flipDisplayVertically" and "mirrorScreen" works like a charm.
The library is "SSD1306.h"
Users browsing this forum: Bing [Bot], Semrush [Bot] and 2 guests
