ADS1256 with ESP32 idf
e2738729
Postby e2738729 » Sun Jan 06, 2019 10:53 pm
Hi Everyone,
I would like to to setup ESP32 as SPI master and 24-bit ADS1256 as slave for data collection. I will use 6 out of 8 ADC channels on the ADS1256.
I have the following questions hopefully you could help me.
1. The ADS1256 has DRDY pin which we could use to trigger the hardware interrupt of the ESP32 to begin the SPI transaction. Should I create a DRDY hardware interrupt ISR which will call the SPI transaction on the ESP32 or does ESP32 have a built-in SPI function to setup the hardware interrupt with this DRDY pin?
2. I don't fully understand the purpose of pre_cb and post_cb callback. When do we use them?
3. The ADS1256 will sample data at the rate of 6kHz, and I would like not to miss the data. Is interrupt better or polling better in this case?
Thanks,
Khoi
Xarlan
Re: ADS1256 with ESP32 idf
Postby Xarlan » Thu Jan 10, 2019 8:12 am
This is an additional functionality.
For example, you have LCD with SPI interface. This LCD has 1 input: "0" - spi transfer data, "1" spi transfer command.
So you can use pre_cb to set this pin.
Try the interrupt or polling.
I use both SPI at 18 MHz in self-develop board and it works
e2738729
Postby e2738729 » Tue Feb 26, 2019 3:13 am
Sorry for the late reply and thank you very much for the reply.
I was able to make ADS1256 to work with my ESP32 but I the latency between SPI transactions is very large. The below is my code:
// Works with all 4 channels, make sure to tie CS LOW properly
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "driver/spi_master.h"
#include "soc/gpio_struct.h"
#include "driver/gpio.h"
#include "rom/ets_sys.h"
#include <time.h>
#define PIN_NUM_MISO 19
#define PIN_NUM_MOSI 23
#define PIN_NUM_CLK  18
#define PIN_NUM_CS   5
#define PIN_NUM_DRDY 27
#define PIN_NUM_RST  13
#define PIN_NUM_LED  25
void ADS1256_cmd(spi_device_handle_t spi, const uint8_t cmd) {
    esp_err_t ret;
    spi_transaction_t t;
    memset(&t, 0, sizeof(t));       //Zero out the transaction
    t.length=8;                     //Command is 8 bits
    t.tx_buffer=&cmd;               //The data is the cmd itself
    ret=spi_device_polling_transmit(spi, &t);  //Transmit!
    assert(ret==ESP_OK);            //Should have had no issues.
uint8_t  ADS1256_read(spi_device_handle_t spi)
    esp_err_t ret;
    t.length=8;
    t.rxlength=8;                 //Len is in bytes, transaction length is in bits.
    t.flags = SPI_TRANS_USE_RXDATA;
    ret = spi_device_polling_transmit(spi, &t);  //Transmit!
    return *(uint8_t*)t.rx_data;
void ADS1256_REG(spi_device_handle_t spi, const uint8_t reg, const uint8_t cmd, const uint8_t data) {
	esp_err_t ret;
	t.length=24;
	t.flags=SPI_TRANS_USE_TXDATA;
	t.tx_data[0] = (0x50 | reg); // REGISTER
	t.tx_data[1] = cmd;          // 2nd command byte, write one register only
	t.tx_data[2] = data;         // Sending data to toggle register
void ADS1256_init(spi_device_handle_t spi) {
	uint8_t reg = 0, cmd = 0, data = 0;
	//	const lcd_init_cmd_t* lcd_init_cmds;
	//Initialize non-SPI GPIOs
	gpio_set_direction(PIN_NUM_RST, GPIO_MODE_OUTPUT);
	gpio_set_direction(PIN_NUM_DRDY, GPIO_MODE_INPUT);
	gpio_set_direction(PIN_NUM_LED, GPIO_MODE_OUTPUT);
	// Set PULL UP for DRDY Pin
	gpio_set_pull_mode(PIN_NUM_DRDY, GPIO_FLOATING);
	// Hold reset level HIGH
	gpio_set_level(PIN_NUM_RST, 1);
	gpio_set_level(PIN_NUM_LED, 0);
	cmd = 0xFE; //Reset to Power-Up Values 0b11111110
	ADS1256_cmd(spi, cmd);
	vTaskDelay(10 / portTICK_PERIOD_MS);
	reg = (0x50 | 0x00); cmd = 0x00; data = 0x01; // 01h => status: MSB First, Auto-Calibration Disabled, Analog Input Buffer Disabled
	ADS1256_cmd(spi, reg); // Setup Status Register
	ADS1256_cmd(spi, data);
	reg = (0x50 | 0x02); cmd = 0x00; data = 0x01; // 01h => Clock Out = Off, Sensor Detect OFF, gain 2
	// 0x02 = 0b10 // 0x00 = 0b00 // 0x01 = 0b01
	ADS1256_cmd(spi, reg); // Setup A/D Control Register
	reg = (0x50 | 0x03); cmd = 0x00; data = 0xF0;  // F0h = 11110000 = 30,000SPS
	// 0x02 = 0b11 // 0x00 = 0b00 // 0x01 = 0b01
	ADS1256_cmd(spi, reg); // Setup A/D Data Rate
	cmd = 0xF0; // Perform Offset and Gain Self-Calibration (F0h)
	// 0xF0 = 0b11110000
void app_main()
	uint16_t counter = 0;
	uint32_t clock_millis;
    esp_err_t ret;
    spi_device_handle_t spi;
    spi_bus_config_t buscfg={
        .miso_io_num=PIN_NUM_MISO,
        .mosi_io_num=PIN_NUM_MOSI,
        .sclk_io_num=PIN_NUM_CLK,
        .quadwp_io_num=-1,
        .quadhd_io_num=-1,
        .max_transfer_sz=0,
    spi_device_interface_config_t devcfg={
        .clock_speed_hz=2800*1000,           //Clock out at 10 MHz
        .mode=1,                                //SPI mode 1
        .spics_io_num=-1,               //CS pin
        .queue_size=7,                          //We want to be able to queue 7 transactions at a time
        .pre_cb= NULL,
		.post_cb = NULL,
    //Initialize the SPI bus
    ret=spi_bus_initialize(VSPI_HOST, &buscfg, 0); // 0 means DMA disabled
    ESP_ERROR_CHECK(ret);
    //Attach the ADS1256 to the SPI bus
    ret=spi_bus_add_device(VSPI_HOST, &devcfg, &spi);
    //Initialize the ADS1256
    ADS1256_init(spi);
	  long adc_val[6] = {0,0,0,0,0,0}; // store readings in array
	  uint8_t mux[6] = {0x08,0x18,0x28,0x38,0x48,0x58};
	  uint8_t i = 0; uint8_t channel = 0;
	vTaskDelay(100 / portTICK_PERIOD_MS);
	setvbuf(stdout, NULL, _IONBF, 0);
	printf("configured, starting\n");
	printf("AIN0	AIN1    AIN2	AIN3    AIN4	AIN5\n");
	while(1){
		  for (i=0; i <= 5; i++){            // read all 6 single ended channels AIN0, AIN1, AIN2, AIN3, AIN4, AIN5
			  channel = mux[i];             // analog in channels #
			  while (gpio_get_level(PIN_NUM_DRDY) == 1) {} ; // Wait until the data read pulls LOW
			  // Switching between channels
			  reg = 0x01;  cmd = 0x00; data = channel; // 1st Command Byte: 0101 0001  0001 = MUX register address 01h
			  ADS1256_REG(spi, reg, cmd, data); // Data Byte(s): xxxx 1000  write the databyte to the register(s)
			  //SYNC command 1111 1100 (0xFC)
			  cmd = 0xFC;
			  //while (!digitalRead(rdy)) {} ;
			  //WAKEUP 0000 0000
			  cmd = 0x00;
			  // Read Data
			  cmd = 0x01;
			  ADS1256_cmd(spi, cmd); // Read Data 0000  0001 (01h)       // ********** Step 3 **********
			  adc_val[i] = ADS1256_read(spi);
			  adc_val[i] <<= 8; //shift to left
			  adc_val[i] |= ADS1256_read(spi);
			  adc_val[i] <<= 8;
			  //ets_delay_us(2);
			  if(adc_val[i] > 0x7fffff){   //if MSB == 1
			  		  adc_val[i] = adc_val[i]-16777216; //do 2's complement
/*		  for (i=0; i <= 5; i++){*/
/*			  	  printf("%ld",adc_val[i]);   // Raw ADC integer value +/- 23 bits*/
/*			  	  printf("      ");*/
/*		  printf("\n");*/
		  vTaskDelay(5 / portTICK_PERIOD_MS);
		  counter = (counter+1)%1000;
		  if (counter == 999) {
		  	clock_millis = (uint32_t) (clock() * 1000 / CLOCKS_PER_SEC);
    			printf("clock_millis: %d\n", clock_millis);
For example, the time delay between the following two transactions
 cmd = 0xFC;
takes 13us.
How would I be able to make the latency smaller? My SPI speed is 2.5MHz, the maximum acceptable speed for ADS1256 is 3.45MHz.
dizcza
Postby dizcza » Sun Jan 21, 2024 9:05 am
Hi e2738729, can you please share your final code?
I'm also searching for ADS1256 ESP-IDF and found no solutions.
Thanks.
Users browsing this forum: markkuk, PetalBot, Qwantbot, trendictionbot and 1 guest
