There is a error When ESP32 use IIS with UART in a project
LeoXie
Postby LeoXie » Thu Jan 10, 2019 1:13 am
Code: Untitled.txt Select all
Hello Everyone,
There is a error When ESP32 use IIS with UART in a project, If I don’t use IIS. The all of UART working is fine, and then, I enable the IIS with UART1 at same time, the follow error is occurred, By the way, the program can be running, but UART not working.
If I enable IIS with all of UART, the program always restart, and I catch the log in below. Register IIS interrupt error that 0x105 was returned.
IIs error.png (113.72 KiB) Viewed 4651 times
This picture shows The IDF version
IDF version.png (53.62 KiB) Viewed 4651 times
Thanks a lot.
Best Regards,
Leo,
ESP_@In逍遥子
Re: There is a error When ESP32 use IIS with UART in a project
Postby ESP_@In逍遥子 » Thu Jan 10, 2019 3:24 am
Could you please run the app using IDF Monitor ("make monitor" or "idf.py monitor") tool? This will produce a readable backtrace.
See monitor.
The resulting backtrace will give more information to figure out what the issue is.
LeoXie
Postby LeoXie » Sat Jan 19, 2019 7:32 am
I am sorry for repley delay.
I was set wrong, I correct it, It's work.
