Is it possible to create custom OTA partitions for more than 1 MB? Do I need to change bootloader for that?
I have tried but not got any success for that.
ota data partition info error
Re: ota data partition info error
Yes, you should; up to 16MB should work just fine. What is the trouble you're running into?
I am getting following warnings while using "Factory APP, Two OTA Definitions" at boot time.
Does anyone has any idea for this type of warning and does it will create any impact on WiFi test?I (31) boot: Espressif ESP32 2nd stage bootloader v. V0.1
I (40) boot: compile time 14:22:28
I (62) boot: SPI Speed : 40MHz
I (62) boot: SPI Mode : DIO
I (62) boot: SPI Flash Size : 16MB
I (64) boot: Partition Table:
I (70) boot: ## Label Usage Type ST Offset Length
I (81) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (92) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (103) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (114) boot: 3 factory factory app 00 00 00010000 00100000
I (125) boot: 4 ota_0 OTA app 00 10 00110000 00100000
I (137) boot: 5 ota_1 OTA app 00 11 00210000 00100000
I (148) boot: End of partition table
I (155) boot: Loading app partition at offset 00010000
I (1172) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512)
I (1173) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x41338 (267064) map
I (1181) boot: segment 2: paddr=0x00061348 vaddr=0x3ffc1740 size=0x0903c ( 36924) load
I (1209) boot: segment 3: paddr=0x0006a38c vaddr=0x40080000 size=0x00400 ( 1024) load
I (1210) boot: segment 4: paddr=0x0006a794 vaddr=0x40080400 size=0x1c608 (116232) load
I (1275) boot: segment 5: paddr=0x00086da4 vaddr=0x400c0000 size=0x00000 ( 0) load
I (1276) boot: segment 6: paddr=0x00086dac vaddr=0x00000000 size=0x0925c ( 37468)
I (1283) boot: segment 7: paddr=0x00090010 vaddr=0x400d0018 size=0x3efcc (257996) map
I (1296) boot: segment 8: paddr=0x000cefe4 vaddr=0x50000000 size=0x00008 ( 8) load
I (1311) heap_alloc_caps: Initializing. RAM available for dynamic allocation:
I (1320) heap_alloc_caps: At 3FFCA77C len 00015884 (86 KiB): DRAM
I (1330) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM
I (1341) heap_alloc_caps: At 4009CA08 len 000035F8 (13 KiB): IRAM
I (1351) cpu_start: Pro cpu up.
I (1356) cpu_start: Single core mode
I (1363) cpu_start: Pro cpu start user code
W (1467) cpu_start: failed to load RF calibration data, falling back to full calibration
I (2860) phy: phy_version: 258, Nov 29 2016, 15:51:07, 0, 2
I (3009) cpu_start: Starting scheduler on PRO CPU.
Regards,
Ritesh Prajapati
Ritesh Prajapati
