Android hotspot requires restarting for ESP32 to reconnect or fails: auth -> init (200) [solved:update to latest master]
Ritesh
Contact:
Re: Android hotspot requires restarting for ESP32 to reconnect or fails: auth -> init (200)
Postby Ritesh » Sat Jan 19, 2019 9:07 am
Ritesh, WiFi debug logging was enabled through menuconfig, sorry not near computer to remember exact name for the next few days.
We are 1 week into the 2 week estimate that liuzhifu provided to wait for a fix, I have not seen anything to test yet.
Ok. Fine. It will be good if you provide few more details regarding issue which you are facing so that I can look and provide some suggestions for that if possible and feasible to test at your side
Regards,
Ritesh Prajapati
jcsbanks
Postby jcsbanks » Sat Jan 19, 2019 10:27 am
Everything I could think of is in post #1 and the fix is in hand from Espressif. Presumably in the closed source WiFi driver.
Ritesh
Contact:
Postby Ritesh » Sat Jan 19, 2019 5:17 pm
Ok. Fine. Let's wait to get solution from Espressif Team.
Regards,
Ritesh Prajapati
jcsbanks
Postby jcsbanks » Sat Jan 26, 2019 12:16 am
If your problem is same as the one I'm talking about, we already have enhancement for it, it will be merged into IDF within about 2 weeks.
Hi @liuzhifu
I have been looking at esp-idf commits and those in your name, but don't yet see anything.
Please could you give us an update on the fix or if there is a delay, advise any fix you may wish us to test?
Thanks,
John
littlesky
Postby littlesky » Mon Jan 28, 2019 12:40 pm
We can reproduce the issue in our lab now. We are investigating it and will fix it ASAP.
littlesky
Postby littlesky » Fri Feb 15, 2019 9:03 am
The bug has been fixed. Please update the IDF branch to check whether it works for you.
jcsbanks
Postby jcsbanks » Fri Feb 15, 2019 4:24 pm
Thanks!
Ritesh
Contact:
Postby Ritesh » Sun Feb 17, 2019 10:26 am
Would you please send us commit I'd in which you have fixed this issue.
Because, We have also fixed this type of same issue after restarting ESP32 into STA mode and not able to connect with few devices while able to connect with few other devices.
Also, Will it be possible to get Disconnect Event after restarting ESP32 device into STA? Just consider that ESP32 device is connected with AP configured before restarting it.
Regards,
Ritesh Prajapati
littlesky
Postby littlesky » Mon Feb 18, 2019 3:24 am
Which version or branch did you use? Yes, it can get disconnect event.
Ritesh
Contact:
Postby Ritesh » Mon Feb 18, 2019 4:16 am
Would you please send us commit I'd in which you have fixed this issue?
Because, We have also faced this type of same issue after restarting ESP32 into STA mode and not able to connect with few devices while able to connect with few other devices.
Regards,
Ritesh Prajapati
Users browsing this forum: PerplexityBot and 17 guests
