[Answered] Assembler language reference manual ...
hydrabus
Contact:
Re: Assembler language reference manual ...
Postby hydrabus » Sat Oct 22, 2016 8:57 pm
1) A way to Count Leading Zeros of a 32bits unsigned integer
Does such feature exist on ESP32 CPU ?
Yes, using NSAU instruction. Compiler will generate it if you use GCC __builtin_clz() intrinsic.
Thanks for the hint and the fact it support asm instruction for that I will test it later to check it generate the right asm code...
2) In a near future write an IDA Pro Processor Module for ESP32 (as only ESP8266 is supported ...)
I have extended the 8266 ida-python plugin with some of the ESP32 instructions (not added FP yet) and am using it personally in day-to-day debugging using ScratchABit disassembler. I can share what i have if you want to work on this.
Could you share your plugin ?
My email is bvernoux at hydrabus.com
4) A way to retrieve number of cycles executed (with accuracy of CPU clock so 240MHz) on 64bits if possible (but I can survive with 32bits), CPU cycle counter (like on ARM CM3... => DWTBase->CYCCNT) is perfect for that (even if timer can be also used ...)
32-bit CPU cycle counter can be queried by reading CCOUNT special register, or equivalently, using xthal_get_ccount function defined in Xtensa HAL.
Thanks for the hint I will check that
igrr
Postby igrr » Mon Oct 24, 2016 3:45 am
I've sent you an email.
hydrabus
Contact:
Postby hydrabus » Mon Oct 24, 2016 9:08 pm
Thanks for all I have replied to your Email
kolban
Re: [Answered] Assembler language reference manual ...
Postby kolban » Fri Jan 12, 2018 4:58 am
Has there been an update on the assembler language reference manual availability?
lesept
Postby lesept » Sat Jan 26, 2019 10:37 am
Hi
Any news about the availability of the assembler language reference manual for ESP32?
Postby Sprite » Mon Jan 28, 2019 2:59 am
Still no change in status, unfortunately...
tosemusername
Postby tosemusername » Thu Jul 08, 2021 12:50 am
So will this ever happen?
Postby Sprite » Thu Jul 08, 2021 1:20 am
It's unlikely that the official Cadence docs ever see a non-NDA-encumbered release... but there is information out there in the form of the compiler etc. We've tried to compile all this publically available info into one one file. It's a bit terse, bit I think it should be helpful when you decide to write assembly.
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot] and 2 guests
