Unable to setup esp AT commands bin
wnoliveira
Postby wnoliveira » Wed Feb 06, 2019 6:54 pm
Hi all.
I am trying yo setup the at-commands module by flashing the esp-at.bin into the esp32 flash. However, I've trie to follow all the instructions on AT commands PDF and also some videos, but nothing works yet.
In the last AT version (https://www.espressif.com/en/support/download/at - V1.13) the avaiable bin files are:
-> at_customize;
-> blank;
-> esp-at;
-> factory;
-> partitions_at;
-> phy_init_data.
Which files I must download to esp, and in what address?
If someone can explain, I will be very aprecciated :D .
Regards.
Re: Unable to setup esp AT commands bin
Postby Sprite » Thu Feb 07, 2019 4:29 am
Have you looked at section 1.2 of the AT documentation?
wnoliveira
Postby wnoliveira » Thu Feb 07, 2019 10:37 am
Definitely.
But it's really not clarifying to what I should download at what addr... :?
igrr
Postby igrr » Thu Feb 07, 2019 11:35 am
The flashing addresses are in /ESP32_AT_BIN/download.config.
wnoliveira
Postby wnoliveira » Thu Feb 07, 2019 12:41 pm
Ok, I didn't notice that. That helps me a lot!
I successfully downloaded the binaries, as you can see in the module's response in my serial monitor:
However, the module doesn't answer the "AT"+CR+LF echo test. The initialization is correct?
wnoliveira
Postby wnoliveira » Thu Feb 07, 2019 2:10 pm
Hi all.
Problem solved :D
The default serial for AT commands are not the same that show logs and download the bin. There is another serial for that.
All is working fine now.
Thanks a lot for the help.
harthenry
Postby harthenry » Fri Feb 15, 2019 8:18 pm
Can you post how you accomplished this task -- I am in the same boat
Fantalucio
Postby Fantalucio » Mon Mar 11, 2019 11:15 am
I'm in these boat too. :-(
Please, help me!
Ciao,
Lucio
wnoliveira
Postby wnoliveira » Sat Mar 23, 2019 12:48 pm
Hi guys. It's basically open the flash addresses in /ESP32_AT_BIN/download.config (open this as a text file). After, be careful to use serial 2 to send and receive AT commands, not the main serial (those standard for dev kits).
Users browsing this forum: Baidu [Spider], ChatGPT-User, meta-externalagent and 1 guest
