Unable to receive TCPIP-packets with wifi callback function
Wamor45
Postby Wamor45 » Thu Jan 05, 2017 7:47 pm
I wrote a small program which once connected to wifi should receive TCPIP packages.
My program is listed below:
nvs_flash_init();
tcpip_adapter_init();
ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
ESP_ERROR_CHECK( esp_wifi_init(&cfg) );
ESP_ERROR_CHECK( esp_wifi_get_mac(WIFI_IF_STA, mac) );
printf("MAC address: " MACSTR "\r\n", MAC2STR(mac));
ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
wifi_config_t sta_config = {
    .sta = {
        .ssid = "my_wifi",
        .password = "123456",
        .bssid_set = false
ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &sta_config) );
ESP_ERROR_CHECK( esp_wifi_internal_reg_rxcb(WIFI_IF_STA, &my_wifi_rxcb) );
ESP_ERROR_CHECK( esp_wifi_start() );
ESP_ERROR_CHECK( esp_wifi_connect() );
When I send some TCP or UDP-packages with another computer on the same network I don't receive any packages in the my_wifi_rxcb call back function. Am I missing some additional initialization or what could be wrong here?
Thank you for your responses,
Wamor
Angus
Re: Unable to receive TCPIP-packets with wifi callback function
Postby Angus » Thu Jan 05, 2017 10:56 pm
Hi Wamor,
esp_wifi_internal_reg_rxcb is an internal function, so it's used to implement the IP stack (LWIP) that runs on top of the WiFi libraries. It may not be what you want in order to exchange TCP/IP packets with another host on the network.
Can you explain a bit more about what you're trying to do? If you take a look at some of the examples in esp-idf that use TCP/IP (like the 'http_request' example, for example) you'll be able to see the recommended way to work with TCP/IP on ESP32.
Angus
kolban
Postby kolban » Fri Jan 06, 2017 3:26 am
Howdy @Wamor,
To follow up on what Mr Angus said ... in case it is useful to you ... here is a snippet I use for a TCP/IP TCP socket client:
https://github.com/nkolban/esp32-snippe ... etClient.c
and one for a TCP/IP TCP socket server:
https://github.com/nkolban/esp32-snippe ... t_server.c
The trick (for me) is to invest time studying generic books on the TCP/IP sockets APIs and there are some fine books and resources available on those subjects. ESP32 sockets API seems to be a high fidelity implementation.
Wamor45
Postby Wamor45 » Fri Jan 06, 2017 8:54 pm
Hello Angus,
What I basically want to do is receiving UDP-packages from a remote computer and send them out as analog values through the DAC of the ESP32. I hope this make sense to you.
Regards,
Wamor
Wamor45
Postby Wamor45 » Fri Jan 06, 2017 8:59 pm
Hello kolban,
Thank you for your response.
I will get me some good books about TCPIP and sockets.
Regards,
Wamor
zjuliwang
Postby zjuliwang » Fri Aug 18, 2017 9:59 am
Hello Angus,
Regards,
Wamor
Hello Angus,nkolban:
How can I get thefeedback (callback function) of tcp's receive or send ?
kolban
Postby kolban » Fri Aug 18, 2017 2:34 pm
Howdy,
You will want to study the API called "sockets". This is a standard C/C++ API that is used to TCP/UDP programming against the TCP/IP protocol. If you can google using the phrase "sockets tutorial", I think you will be rewarded by a whole host of articles.
I am also a fan of books on a subject and there are a wealth at Amazon.
zjuliwang
Postby zjuliwang » Wed Aug 23, 2017 7:00 am
Howdy,
HI kolban:
I have googled the phrase and found the socket API ,they looks nearly the same as ESP32IDF,I don't see any callback function in ESP32IDF,when I used 8266 ,there were many callback functions like sendback_callback(); I think lwip must have the callback function. if not,how can I send or recieve datas one by one continuely? :lol:
kolban
Postby kolban » Thu Aug 24, 2017 10:04 pm
With TCP/IP sockets API there isn't a "callback" event processing system. Instead, most of the sockets API calls are blocking. For example, if you execute recv() to read data, the call will block until data is made available. Now you have choices that involve task processing. You can create a FreeRTOS task for each socket upon which you want to simultaneously listen. An alternative design is to use the TCP/IP select() API call. This will take an array of sockets as input and will block watching them "all" simultaneously. You will unblock when the first of them has data available to be read without blocking.
tele_player
Postby tele_player » Fri Aug 25, 2017 12:57 am
select() has a timeout argument which can be used to set no block, block until timeout, or block forever.
Users browsing this forum: Applebot, PerplexityBot, Qwantbot and 1 guest
