Preferred Antenna for ESP32-WROOM-32U module
Bhavik4016
Postby Bhavik4016 » Fri Nov 16, 2018 6:20 am
We are planning to use ESP32-WROOM-32U in one of the our product for BLE communication.
Can any suggest for particular U.FL antenna for effective wireless range ??
Franco
Re: Preferred Antenna for ESP32-WROOM-32U module
Postby Franco » Sat Nov 17, 2018 4:31 pm
hello Bhavic, I will PM you the DS of the antenna used for certifications of the U modules.
Bhavik4016
Postby Bhavik4016 » Tue Nov 20, 2018 6:22 am
KonradZ
Postby KonradZ » Wed Feb 20, 2019 11:12 am
Could you also send me information about antenna for ESP32-WROOM-32U module for WiFi + BT project so that EMC pre-compliance will stand ?
PascalR
Postby PascalR » Mon Feb 25, 2019 5:14 pm
Would you mind, sharing with me the DS of the antenna used for certifications of the ESP32-WROOM-32U module?
Thank you !
Franco
Postby Franco » Sat Mar 02, 2019 4:50 pm
I have sent the antenna information in PM to whom asked.
PatrikB
Postby PatrikB » Sat Mar 02, 2019 5:34 pm
Could you share the same information for ESP-WROVER-I and IB?
Arend48
Postby Arend48 » Wed Mar 06, 2019 8:22 pm
Code: Untitled.txt Select all
Franco, could you share antenna info with me for the ESP32-Wroom-32U
djmcmath
Postby djmcmath » Thu May 02, 2019 11:40 pm
Franco, I am also very interested in this information. Can you please share the antenna info with me as well?
Also, dumb question, but ... if everyone is asking the same question, is there a good reason not to just post it in the forum?
Thanks,
Dan
Franco
Postby Franco » Mon May 06, 2019 10:44 am
Hi All, you can download the antenna datasheet from here https://1drv.ms/b/s!Aucw7OQw7IKAiu0jzN2Ov-ISOTl9sQ
