I am using the GPIO trigger factory reset feature and I have a question.
In the documentation it says the following:
CONFIG_BOOTLOADER_NUM_PIN_FACTORY_RESET- number of the GPIO input for factory reset uses to trigger a factory reset, this GPIO must be pulled low on reset to trigger this.
CONFIG_BOOTLOADER_HOLD_TIME_GPIO- this is hold time of GPIO for reset/test mode (by default 5 seconds). The GPIO must be held low continuously for this period of time after reset before a factory reset or test partition boot (as applicable) is performed.
Is this regardless of what type off reset that is carried out? Power on reset, Deep sleep reset ...
I was hoping that it only took action on power on reset.
Re: GPIO trigger factory reset
My experience is it only works when power on (Power on reset) or hard reset via reset pin
OK!My experience is it only works when power on (Power on reset) or hard reset via reset pin
I have tried using gpio4 with wake up enabled as well. In deep sleep if I push the button and hold it, it executes the factory reset.
My hope was that it also require that I toggle the enable pin.
Users browsing this forum: Semrush [Bot] and 1 guest
