internet unavailable when connected to AP(Wi-Fi) of ESP32 DevKit,
jjmin.liang
I'm writing a program that working with AP mode on ESP32 DevKit, but when my iOS device connected to the AP that created by ESP32, my iOS can't access internet. but when I use other type of AP(e.g the AP of GoPro camera), even I connected them, I still can use my Cellular network to access internet.
Is there some setting I missed in esp32? I want to keep internet available when connected to the AP on ESP32.
Thanks!
Thanks!
jjmin.liang
Re: internet unavailable when connected to AP(Wi-Fi) of ESP32 DevKit,
@WiFive
Thanks for your reply, I have read the link you provide for serval times, and do some search for "clear gateway address" and other similarly, but still no idea how to do that..
the following is the public function in dhcpserver.h, which one can I use to clear gateway address?
void dhcps_start(struct netif *netif, ip4_addr_t ip);
void dhcps_stop(struct netif *netif);
void *dhcps_option_info(u8_t op_id, u32_t opt_len);
void dhcps_set_option_info(u8_t op_id, void *opt_info, u32_t opt_len);
bool dhcp_search_ip_on_mac(u8_t *mac, ip4_addr_t *ip);
void dhcps_dns_setserver(const ip_addr_t *dnsserver);
ip4_addr_t dhcps_dns_getserver();
void dhcps_set_new_lease_cb(dhcps_cb_t cb);
jjmin.liang
after the tcpip_adapter_init called, I've set a static ip to my AP:
Do I need call these code again while SYSTEM_EVENT_AP_START received?
tcpip_adapter_ip_info_t info;
memset(&info, 0, sizeof(info));
IP4_ADDR(&info.ip, 192, 168, 1, 1);
IP4_ADDR(&info.gw, 192, 168, 1, 1);//ESP acts as router, so gw addr will be its own addr
IP4_ADDR(&info.netmask, 255, 255, 255, 0);
ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &info));
// start the DHCP server
ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP));
jjmin.liang
ah..call the tcpip_adapter_set_ip_info again in the SYSTEM_EVENT_AP_START is not work, connect the AP, and after 10-15 seconds, the internet on my iOS device is not unavailable.
jjmin.liang
hello, does any body have idea?
Interesting about the Garmin device. What device is it? Does it prevent hijacking the internet connection on both iOS and Android?
Here's what I have after struggling with this as well. It seems to work for iOS, but not always working in Android.
this is in main() before initializing WiFi:
Hope it helps.
tcpip_adapter_init();
tcpip_adapter_ip_info_t info = {0};
tcpip_adapter_dns_info_t dns_info = {0};
IP_ADDR4(&dns_info.ip, 0, 0, 0, 0);
IP4_ADDR(&info.ip, 192, 168, 4, 1);
IP4_ADDR(&info.gw, 0, 0, 0, 0);
ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP));
dhcps_dns_setserver(&(dns_info.ip));
uint8_t opt_val = 0; // don't supply a dns server via dhcps
//ESP_ERROR_CHECK(tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, TCPIP_ADAPTER_DOMAIN_NAME_SERVER, &opt_val, 1)); // don't supply a dns server via dhcps
ESP_ERROR_CHECK(tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, TCPIP_ADAPTER_ROUTER_SOLICITATION_ADDRESS, &opt_val, 1)); // don't supply a gateway (router) via dhcps option 3
Hi jjmin,
Would you please let me know like how you are using ESP32 device? I think you are using ESP32 device into AP mode and you are trying to connect your IoS device with that ESP32.
Let me correct if I am wrong at any point.
So, I just want to know that ESP32 device is configired as AP or AP+STA mode? So that I can help you to resolve your issue.
Regards,
Ritesh Prajapati
Ritesh Prajapati
jjmin.liang
Hi Ritesh,
Thanks for you reply! I still working with this issue, but no idea yet
Yeah, you are right, My ESP32 device is working on AP mode, and at the booting time, I've set the reset the IP address and the gateway.
here is the code that I setting the Ip address and the gateway:
here is the code that initialize the AP of WIFI:
main()
if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
// OTA app partition table has a smaller NVS partition size than the non-OTA
// partition table. This size mismatch may cause NVS initialization to fail.
// If this happens, we erase NVS partition and initialize NVS again.
ESP_ERROR_CHECK(nvs_flash_erase());
err = nvs_flash_init();
ESP_ERROR_CHECK( err );
WIFIAP::sharedInstance()->start(ssid, password);
// here is the implementation of startAPMode
void WIFIAP::start(string ssid, string pasword)
wifi_config_t wifi_config;
memset(&wifi_config, 0, sizeof(wifi_config_t));
strcpy((char*)wifi_config.ap.ssid, ssid.c_str());
wifi_config.ap.ssid_len = ssid.size();
wifi_config.ap.max_connection = 1;
if (pasword.size() == 0) {
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
} else {
strcpy((char*)wifi_config.ap.password, pasword.c_str());
wifi_config.ap.authmode = WIFI_AUTH_WPA_WPA2_PSK;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "initialize done. ssid: %s", wifi_config.sta.ssid);
Hi,Hi Ritesh,
here is the code that I setting the Ip address and the gateway:here is the code that initialize the AP of WIFI:Code: Select all
tcpip_adapter_ip_info_t info; memset(&info, 0, sizeof(info)); IP4_ADDR(&info.ip, 192, 168, 1, 1); IP4_ADDR(&info.gw, 192, 168, 1, 1);//ESP acts as router, so gw addr will be its own addr IP4_ADDR(&info.netmask, 255, 255, 255, 0); ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &info)); // start the DHCP server ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP));Code: Select all
main() { if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) { // OTA app partition table has a smaller NVS partition size than the non-OTA // partition table. This size mismatch may cause NVS initialization to fail. // If this happens, we erase NVS partition and initialize NVS again. ESP_ERROR_CHECK(nvs_flash_erase()); err = nvs_flash_init(); } ESP_ERROR_CHECK( err ); tcpip_adapter_init(); WIFIAP::sharedInstance()->start(ssid, password); .... } // here is the implementation of startAPMode void WIFIAP::start(string ssid, string pasword) { wifi_config_t wifi_config; memset(&wifi_config, 0, sizeof(wifi_config_t)); strcpy((char*)wifi_config.ap.ssid, ssid.c_str()); wifi_config.ap.ssid_len = ssid.size(); wifi_config.ap.max_connection = 1; if (pasword.size() == 0) { wifi_config.ap.authmode = WIFI_AUTH_OPEN; } else { strcpy((char*)wifi_config.ap.password, pasword.c_str()); wifi_config.ap.authmode = WIFI_AUTH_WPA_WPA2_PSK; } ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP)); ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config)); ESP_ERROR_CHECK(esp_wifi_start()); ESP_LOGI(TAG, "initialize done. ssid: %s", wifi_config.sta.ssid); }
Yes. obviously you can not access internet from ESP32 device if it is working into AP mode as you are doing one kind of offline communication with it.
So, If you connect your mobile device or any iOS mobile device with ESP32 which is configured and up with AP mode then it will only be able to communicate your mobile device with ESP32 device only. You can not access internet with that scenario.
So, you might need to create one kind of bridge or AP+STA mode to do it like that way but still need to look like how we can achieve with that.
SDK Developer can suggest here to achieve what you want with ESP32 Device.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Applebot, Bing [Bot], Semrush [Bot] and 3 guests
